Question about Panasonic KX-TG1033S Cordless Phone
I have KX-TG1033S PHONE I NEED TO KNOW HOW to unblock can block a number
Posted by Juanita b Carmine on
5 Related Answers
freetek
Steve Allison
  • 5569 Answers
SOURCE: Does not know how to delete calls
If you are talking about the answering machine, typically, the erase button deletes tha last call, and a second tap erases all stored messages.
If you no longer have the user guide, you can download it here:
http://www.generalmanual.com/down.php?link=aHR0cDovL3NlcnZpY2UudXMucGFuYXNvbmljLmNvbS9PUEVSTUFOUERGL0tYVEcxMDMyLnBkZg%3D%3D
Posted on Sep 03, 2008
Anonymous
  • 76 Answers
SOURCE: remote access
I have a very similar Panasonic phone, but I don't use the remote feature. In the past I had a similiar phone where I just dialed the phone number and entered a three digit code that I assigned and was able to listen to the messages. Here is a link to the owner's manual. Look on page 29-30.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/model.KX-TG1033S
Posted on Oct 02, 2008
Anonymous
  • 11 Answers
SOURCE: HOW DO I UNBLOCK A BLOCKED PHONE NUMBER
Go to: MENU press: # Enter direct No. :217 Search number then Erase or Edit
Posted on Jul 12, 2009
Anonymous
SOURCE: kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
Posted on Feb 28, 2010
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Dear Sir, I am using KX-TEM824 PABX system and
That doesn't explain so well in a free forum. Try the features manual under TRS (toll restriction). COS (Class of Service) and Verified Toll calling. With restrictions, you set up a numbering plan that will bar mobile calls, then either verify and override, or alow only certain phones the ability to dial outside calls to those numbers. If you absolutely have to allow access to certain mobiles, you can add them to the Speed Dial tables where the call can be allowed by the fact it's in a speed call table.
It will take you 30-60 minutes to read and set up the programming.
Carl
Posted on Dec 23, 2010
I have a Panasonic digital cordless phone model KX-TGE210. I accidentally block a number on my phone that I need to unblock to receive calls. Can you tell me how to unblock a number?
I have similar phone.
Press Menu then enter #217 to edit blocked numbers.
Use up or down arrow to scroll through numbers.
You can erase or edit blocked numbers.
For more info, see manual at: http://www.manualslib.com/manual/754430/Panasonic-Kx-Tge210.html?page=1
Mar 08, 2016 | Panasonic Lands Phones
How to clear a memory full in the block feature on the KX-TG4031?
I have a KX-TG7644. Had to look harder for the Call Block directory. The manual really didn't help much. Press "Menu", go down to "Initial Settings", go to "Call Block". You can access the list and delete all or part to open up memory space. I had to do this after all the election calls.
Jul 09, 2011 | Panasonic KX-TG1033S Cordless Phone
Kx-TGA641T how does one unblock blocked number
numbers
you can also edit:
■ Editing a number:
Sep 28, 2009 | Panasonic Lands Phones
How do you UNblock a blocked number
Go to menu then initial setting then call block. Scroll to find the blocked number and choose erase. That erases it from the call block menu on your phone.
Sep 17, 2009 | Panasonic KX-TG1033S Cordless Phone
How to unblock a number
Your Anonymous Call Rejection feature is locked ON and you probably didn't notice it. Pick up the phone and dial*87. It will say that the ACR is now OFF. This should solve the problem :)
Aug 21, 2009 | Panasonic KX-TG1033S Cordless Phone
Unblock my restricted number
There is no cost to perform this action on a per call basis. Check with AT&T...you enter something like *87 or *82 before you dial the phone number.
Jul 12, 2009 | Panasonic KX-TG1033S Cordless Phone
Unblocking calls
a caller decides whether or not their number will be displayed on a call display unit. you can't do anything about it.
Jun 19, 2009 | Panasonic KX-TG1033S Cordless Phone
I have blocked a number and need to unblock it in the near future. How can I do this? I have a Panasonic model # KT-TGA91T.
Contact your telephone company if you want it permanently corrected, or if you would, like dial *67 then your phone number.
Jan 21, 2009 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
163 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
