Question about Pioneer Televison & Video
Fire stick my tv pioneer 42 plasma has only hd1m port can I make fire stick work on this set. Nohd2m
  • Pioneer Master
  • 2,678 Answers
As long as you have a HDMI port you should be able to use it. If you have only one, you won't be able to have any other player plugged in. The firestick doesn't care if the port it is plugged into is labeled 1 or 2 or 3
Posted on Nov 09, 2019
6ya staff
SOURCE:
Anonymous
  • 7 Answers
SOURCE: 42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Posted on Jun 07, 2008
Anonymous
SOURCE: 1394 Fire Wire
I change my PC to new windows vista and the new PC don't recognize any VCR throw firewire, but the machine recognize my canon LG-2 by firewire. I need something special like a special driver to run my JVC's BR-DV3000 & BR-HD50 for capture video
in vegas pro 8.0?
Posted on Aug 19, 2008
Anonymous
  • 20 Answers
SOURCE: Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Posted on Nov 01, 2008
SOURCE: My panasonic 42" plasma wont turn on, but the power light blinks
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on Apr 17, 2010
ssmelser54
SOURCE: Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Posted on Feb 02, 2011
My firestick is frozen on home page
Fire Stick frozen on home screen
Restarting your device can resolve many issues-just disconnect the power cord (from the back of the device or from the power outlet), and then plug it back in. You can also use your remote to restart your device. Press and hold the Select and Play/Pause buttons at the same time, for about five seconds.
Amazon.com Help: Fire TV is Frozen, Blank, or Won't Power On
https://www.amazon.com/gp/help/customer/display.html?nodeId=202154650 Search for: Fire Stick frozen on home screen
firestick is frozen on home page Google Search
Jun 12, 2018 | Televison & Video
How can I watch Netflix on pioneer elite pro-111fd
You will need to connect a streaming media player to the Pioneer Elite Pro-111FD. This can be your computer (make sure to set the HDMI input to PC, if needed) or a Roku or Fire (either the stick format or the box). Set the TV to the correct HDMI input and then access Netflix on the media player.
The Ethernet port on this TV is only for use with media saved to your local network. The TV cannot directly use the Netflix app or website. See the manual for details on the Home Media Gallery Server features of the Pro-111FD. The manual is available from Pioneer on the product page: https://www.pioneerelectronics.com/PUSA/Home/Plasma/PRO-111FD . The direct link to the manual is currently https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/PRO-151FD_OperatingInstructions0905.pdf .
I hope this helps.
Mar 03, 2018 | Pioneer Televison & Video
Setting up fireTV stick. It's plugged in to TV and power.ts Tried all inputs on TV. None worked. What am I doing wrong???
not sure if this link will help you out.
1. The easy way (5 mins)
  1. Plug your Amazon Fire TV Stick into your TV and plug the USB power cable into a spare USB port or use the power adapter.
  2. Go to Settings. ...
  3. Go back to the homescreen and install an app called Downloader - this will be listed under the Popular Fire TV apps section.
More items...
How to install Kodi on the Amazon Fire TV Stick: 3 BEST ways to ...
how to set fireTV stick Google Search
Oct 28, 2017 | Televison & Video
How do I install sling tv to my fire stick
I just googled your question and got this:
How does it work?
It's easy! Here's how:
  1. Connect your Amazon Fire TV or Amazon Fire TV Stick device to your TV's HDMI port, and set it up as its instructions specify.
  2. Download the Slingplayer for Fire TV app to your Fire TV device.
  3. Using your Amazon Fire TV remote control, scroll to Apps. Select the Slingplayer for Fire TV app to launch it.
  4. Sign into your Sling Account.
  5. Use the Directory to connect to your Slingbox.
  6. Enjoy watching your programs ... no matter where your TV is!
Apr 25, 2017 | Televison & Video
How do I install sling tv to my fire stick?
I googled your question and got this
How does it work?
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
Dec 23, 2016 | Televison & Video
Fire tv stick unsupport
well there's your first problem right there !! fire sticks plug into a USB port not a hdmi port if your tv doesn't have a USB port then its not for using with a firestick
Oct 20, 2016 | Televison & Video
Connect my amazon fire tv stick
The stick will only work with a tv with an hdmi port.
Jul 12, 2016 | Amazon Fire TV Stick
Can i install a amazon fire tv stick the u s b will not plug in
Amazon.com: Customer Reviews: Amazon Fire TV Stick
www.amazon.com/Amazon...Fire-TV-Stick/.../B00GD...
Amazon.com, Inc.It doesn't even play all the games that can run on the Fire TV box. Also note ... Q: CanI use my TV's USB port to power the Fire TV Stick? ... A USB port on your TV or other equipment probably will not work. ..... You can plug the Fire Stick's USB cable into theUSB port on your TV and it should work (depending on your TV ).
Amazon.com: Customer Discussions: Fire stick and Samsung TV issues
www.amazon.com/forum/fire?cdForum...cdThread...
Amazon.com, Inc.Getting a brand new replacement from Amazon did not help, seems to be some other HW or SW issue. Anyone else run into similar issues? ... I also have a Samsung TV and the Fire Stick is not recognized through HDMI or USB connections. .... Can youplug the HDMI extender cable into your TV and will the Fire TV stick fix
Dec 25, 2015 | Sanyo DP42849 42 in. HDTV
Televison & Video Logo
136 people viewed this question
Top Pioneer Televison & Video Experts
Marvin
Marvin
Ekse
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
