Question about Bernina Sewing Machines
My bernina aurora 440 sewing machine is making a high pitch humming noise when I turn it on
Posted by mary clemens on
R.A. Ellis
  • Bernina Master
  • 12,731 Answers
These machines do make a noise during start-up, but if it stops after the sewing machine has gone through the set-up, it is probably okay. However, if the noise continues, it should probably be taken for a check-up. Even so, if you are worried, a check-up may still be helpful.
Posted on Feb 12, 2017
How do I get my BSR to work on my 440QE? I plugged it in, but I don't see a light on the foot. Can't make BSR 2 work? BSR2 is on my screen, but won't run.
Try BSR 1. I have a 440 and only one of the BSR settings works--don't know why--just is.
Manual:
BERNINA aurora 440 QE Support BERNINA
Check to make sure the BSR is firmly plugged into the machine head. Don't know why they made this so difficult. I find I usually have to practically stand on my head to find it and then plug it in.
If it still does not work, perhaps Bernina did not calibrate the BSR to your machine. They recommend, whenever it goes for service, to be sure to bring the buttonhole foot and BSR so they can be calibrated.
Apr 04, 2017 | Sewing Machines
Where is the bobbin switch for bernina 440
What do you mean by "bobbin switch?" I have a 440 but cannot think of what you could possibly be asking.
Nov 04, 2016 | Bernina Sewing Machines
Makes a high-pitched whine when turned on
Are you sure you have not knocked the bobbin winder to the 'on' position? It makes a high whiny noise. Guess how I know? :-)
Jul 07, 2015 | Bernina Sewing Machines
Bernina Aurora 450 Sewing Machine
If the buzzing noise is coming from the motor it may be the suppressor on the way out and unfortunately for a Bernina it will be a shop job, if the buzzing is coming from the foot control then you can undo the foot control and take out the suppressor and discard it.
Mar 10, 2010 | Sewing Machines
Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Mar 26, 2009 | Bernina Artista 180
Sewing Machines Logo
142 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Wayne Buss
Harjeet Singh
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
