Question about Jensen Car Audio & Video
SOURCE: my jensen vm9214 wont play
This is one video lock condition that you need to bypassed. In THIS LINK can find the solution: Jensen-Video-Bypass-Lockout-VM9214-VM9414-VM9324
I heard this same problem, if it plays when its parked then it has a
little safety feature that involves a wire, maybe pink in color for your
headunit that will only allow it to play when parked. Now if you
splice it into the red or yellow, I'd choose red since its not constant,
it will play movies anytime.
If it won't play them even when parked then it is not hooked up to a
wire or its hooked up to ground and therefor should be hooked to a
positive wire, red or yellow. If you didn't put it in yourself then you
can take it to an audio shop, maybe check in phonebook for someone
local.
But the easy way would be to use a bypass code since there is ojne for your hu. I copy these instructions from ecoustics.com The parking brake bypass procedure is as follows:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
I don't know if it really works but you could try it, if not use the wiring method above: ecoustics.com/bbs/4/278797.
Hope helps.
Posted on Oct 14, 2010
SOURCE: jensen vm9214 when i hook my indash to battery only the src button is red it wont turn on t
Did you connect the power, ground and accessory? When doing a bench test for operation, these wires need to be connected.
Posted on Oct 01, 2012
SOURCE: I have a Jensen vm9214 touch screen
Good. It is a grand set. Keep it. Never allow anybody even to touch on it.
Posted on Aug 13, 2016
