Question about Bunn Coffee Makers & Espresso Machines
My Bunn nhbx-b leaks water when brewing coffee
pawnpower
    Master:
  • 851 Answers
You could remove the cover and look for the connection that isn't connected properly - - be careful not to touch electrical connections/bare wires when cover is off - or take it to a technician - or contact Bunn directly for suggestions.
regards,
Posted on Mar 08, 2017
How to remove the top water resivour from a nhbx bunn coffee maker
lift filler led and remove 2screws on top of reservoir
Then remove 4 screws that hold the reservoir on an you should be able to lift it off
Sep 03, 2014 | Bunn NHBX-B Contemporary 10-Cup Home...
Bunn nhbx leaks water
Jun 30, 2014 | Bunn NHBX
Bunn nhbx leaks out of the bottom
according to BUNN it is not repairable . they won't sell the parts needed
Jan 19, 2014 | Bunn NHBX-B Contemporary 10-Cup Home...
I have a Bunn coffee maker with date code of 401406. It is almost 4 years old and still brews perfectly. The warming plate does not heat up any longer so the coffee will not stay warm after it is brewed....
The manual for this coffee maker can be found at this link:
http://manualheaven.com/assets/bunn-nhbx-b-contemporary-coffee-maker-manual.pdf
While the manual does not contain repair instructions, it does have some troubleshooting tips to follow if your coffee is not staying hot.
May 04, 2011 | Bunn NHB Coffee Maker
New Bunn NHBX takes about an hour to make 10 cups of coffee. Water is dispensed drop by drop instead of a stream. 4 dispensing holes are clean
It sounds like you might have a problem with the water tubing. If you will call Customer Service at 800-352-2866 we will be happy to assist you with this issue.
Sep 21, 2010 | Bunn NHBX-B Contemporary 10-Cup Home...
I have a bunn coffee maker the nhbx is the # it is leaking water from the resevoir
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
May 12, 2010 | Bunn NHB Coffee Maker
I have a bunn coffee maker the NHBX is the # it is leaking water from the resevoir
If you will locate the date code on the bottom of the unit and then call Customer Service, the machine will be replaced at no cost or if over 3 years old, at a reduced price.
Mar 21, 2010 | Bunn NHB Coffee Maker
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Coffee Makers & Espresso Machines Logo
151 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
