Question about Smith Pool & Spa
Wiring a smith and jones 1 hp electric motor for 220. The diagram is not very helpful. I have a red and black hot lead and a white neutral. Where do they all go? I want to make the motor go ccw.
Posted by Jason Toman-Jones on
domberg2008
    New Friend:
  • 56 Answers
Ok from what I read on the diagram take one lead to P1 cap of P2 T3 T8 and T2 are together and T4 and T5 are put to the second lead
If you want to change direction exchange T5 and T8
Posted on Feb 15, 2017
5 Related Answers
larryyb
Larry Youngblood
  • 291 Answers
SOURCE: New Wall Oven wiring
on a 220v unit you dont use the 110 ,,, connect the red and black as power and the white as ground / larry
Posted on Dec 12, 2008
Anonymous
  • 3 Answers
SOURCE: Need connection diagram, AO Smith electric motor FDL 1056
red is low blue med black high
Posted on Feb 19, 2009
Anonymous
  • 96 Answers
SOURCE: Need connection diagram, AO Smith motor FDL 1056
Black is high , Blue is med. , red is low
Nathan Ellsworth
  • 92 Answers
SOURCE: just replaced a rheem oem 1/6 hp motor 3 wires
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Posted on Jul 10, 2009
A Miller
  • 8404 Answers
SOURCE: 120v hot tub wiring diagram
I would expect your tub is either 110 or 220. Currently you are set up for 110. Based on that ... you disregard the red wire.
If your tub can run on 220, you should run it on 220 as this is more economical.
You should probably have an electrician check this out and make any changes to assure proper and SAFE operation of your tub. You are using a GFI, correct?
Thanks for your interest in FixYa.com
Posted on May 16, 2010
Wiring diegram
should come wired for 220 volts one of the hot wires and the other colored or black wire should get 220 between them from each to ground 120 volts 1st hot to L1 2nd hot to L2 green to ground or case
Feb 10, 2018 | Smith Pool & Spa
How to wire air compressor motor to 220v
Insulate brown means cap and tape.
240Volt should not have neutral wire
http://waterheatertimer.org/Basic-house-wiring.html#basic-wire
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
240Volt coming from breaker box will have 2 hot wires... and either hot wire is same no matter wire color
http://waterheatertimer.org/Color-codewire.html#motor
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 07, 2014 | Hardware & Accessories
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
220 Volt Wiring Diagram
black hot red hot white neutral green ground get help to be safe
Nov 01, 2013 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Wiring a Pump for 220
Should only be two wires out of the pump. Three if you count ground. If you have two blacks and a white, Hot and Hot go to the black, Ground or Neutral goes to the white. If more wires, please respond.
Jul 01, 2012 | AO Smith Hayward Pool Pump Motor 3/4 HP...
How towire a 220/110 7 wire single phase motor to 2 wire plus ground switch
This is very simple, but you need to make sure you have the correct wires in hand. If you are wiring a 220/110 motor, and you are wiring it for 110 use, you will only be using 3 wires. If this motor has 7 wires, most you will need to cap off.All you need to use are P-1/Line 1 is your 110 hot. Cap off T-4, 2, and 5, Line 2. That would be used for 220 volts. P- 1 will go to your hot wire on press. On the new motor, T-8, P-2, and t-3 you say are insulated? You will need a Neutral wire to tie to the other line wire coming from the press. And the 3rd wire will be your ground. So, P-1 is hot to your press wiring, t-4,2, and 5 capped off. T-8, P-2, and T-3 has to be a Neutral wire, I would think that if T-4,2,and 5 are line -2, this would be for 220 volts. You are being confused by so many wires. You will only need to use P-1 power for 110 to press power wire, find which wires are Neutral and a ground that will go to your press wiring.P-1 will go to Red if this is hot to the press, Black to Neutral, and on the new motor you will see what color is ground, normally green or bare copper. 3 wires only. You will only need the p-1 hot, a neutral, normally white but may be black on the new motor, and a ground. Look at the Diagram on the new motor, and it will tell you the combination. P-1, Neutral, ground, and cap off the other 4 wires. I hope I havent confused you more, it is very simple, its just the colors of the wires the are confusing you and the amount. Just remember, you only need to use 3 of the, P-1, Neutral, and a ground.
Shastalaker7
Apr 06, 2012 | Heating & Cooling
Need to change a motor. The leads are not marked . How do determine which leads go where on the new motor ?
Without motor info, Brand, hp, voltage i could not say for sure, but white wire is neutral, black is hot and 220 volt red is hot also. should be wiring diagram on motor or back of connection plate
Dec 23, 2010 | IDEAL Vol-Con Xl Voltage/Continuity Tester
I had a hayward 1 hp super pump which began having problems. Purchased a century centurion a. o. smith 1 hp pump Question 1 How do I know for certain that dark grey wire running from my electric is to...
If this is a new motor you purchased, it should indicate whether it's 110v, or 220v. Also the sticker on the motor should show wiring for 110, and/or 220v. when you remove the cap on the back of the motor it will usually have a little plug, or switch that allows you to change from 110 to 220. Older motors you had remove wire nuts and swap wires. L1 vs L2 don't really matter as long as your voltage is correct if it's 110, then you got 1 hot and 1 neutral. Neutral should be white, and Hot should be black, Red, or possible blue or purple. If you got 220V then you have 2 hot wires and no neutral. If you can't tell the current voltage by looking at the sticker and the wires in the back of the motor, and the documentation that came with it, then you should go back to where you got it and make sure. A local motor shop will also probably check it and tell you for free. Now you mentioned grey and pink wires. If your referring to the wires coming from your supply and not the old motor, then I assume they are white and black (or maybe blue or purple) and are discolored from age and heat. the colors of the wires inside the motor can vary from motor to motor, so you need to follow the sticker on the side.
Sep 22, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
I have a new A O Smith B861 motor I want to
Thank you for posting your question here on Fixya.com.
I am not sure what you mean by "center wire". For 230V single phase you should have 2 hot line leads (115V each) and a ground wire. Set the motor leads as the nameplate shows for the high voltage connection and attach your line leads where the two lines are indicated. If you have a 3+Grd wire drop DO NOT connect the neutral, insulate it and leave it unconnected. It will not matter which line lead connects to which motor line wire as far as rotation direction. To change rotation, if the motor allows it, you reverse the start winding leads as directed on your nameplate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Sep 17, 2010 | AO Smith A O Smith Motors A O Smith 2hp...
Breaker keeps tripping when turning on pump.
The red and black wires if ran correctly are the load lines(power). The white is neutral or ground. If its a 1/2 to1-1/2 hp motor connect the red and black wires to terminals #1 and #4. If its 2 hp use #1 and #4. If its 3 hp use #2 and #4. Connect the white wire to the green colored screw. A grounding conductor should always be connected under the green grounding screw, which is located within the terminal compartment of the motor. You can check the breaker for the wire colors, one should be black and the other red. The white wire should be terminated to the neutral/ground bar in the can.
May 16, 2010 | AO Smith 1 HP 115/230V 56C Replacement...
Pool & Spa Logo
2,456 people viewed this question
Top Smith Pool & Spa Experts
Bill Jordan
Steve Slater
Tom Chichester
Are you a Smith Pool and Spa Expert? Answer questions, earn points and help others
