I've exchanged ac adapters and the cd player itself, but I still can't get it to play using the ac adapter.
SOURCE: nextbase dvd
If it works fine with only the battery, then the lcd should be fine. Your power adapter might be bad.
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
SOURCE: Need a new ac adapter for a DVP615 portable dvd/cd player (Zenith
You can buy a new one by clicking on the hyperlink:
buy replacement ac power adapter charger cord ZENITH DVP615
SOURCE: Durabrand Portable DVD player (Dura-7) AC Adapter
after losing the adapter to my portable dvd player i went to the localwalmart and in the electronics section they had all kinds of ac adapters. a generic one with the same volt rating as your old one should do the trick.
SOURCE: Need AC Adapter #PA009UG01
click on hyperlink:
buy replacement ac power charger adapter Audiovox pvs33116
