Question about Sharp Ar 5316
I have a sharp AR5316, and I am using it as a printer and copier, how can I use this device as a scanner? is it possible to do that? if yes,what is the software to use it as a scanner
Posted by mohammad ali... on
Tom Chichester
    Top Expert:
  • Sharp Master
  • 55,647 Answers
If your Sharp AR5316 was not originally designed as an "all-in-one", you can't add that capability.
Posted on Feb 10, 2017
Testimonial: "it is all in one, but the driver i found and have it,is just for print"
How to cancel L1 00 error code in sharper AR5316 coppier when it is on and does not copy out paper or roll
check the scanner feeder rollers and feeder clutch
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 06, 2015 | Sharp Ar 5316
Drivers and software for SHARP AR 5316 windows 7 32
Sharp AR-5316 copier software doesnot support the window 7, it is suitable for window XP, Wndow 98/Me/2000/NT4.0
Mar 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
I want a driver 4 sharp ar5316 in ubantu ultimate edition 2.3
Hi there, Sharp AR5316 comes with installation CD when new. This gives those with computers a chance to use it as a printer only when they correctly install it. They quote several operating system that it can accommodate and unfortunately, ubuntu is not among them because it is only compatible with windows like windowsxp. For you to use it as a printer, please install windowsxp on your computer and follow the instructions on it. Best wishes.
Aug 03, 2010 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR 5316 is blicking h and then 2 please wat do i do...and pls how many copy can i make wit it in a day
An error code of H2 om a sharp 5316 indicates an open thermistor.A thermistor is a small electronic device that regulates temperature.You will need to call a copier technician.An Ar5316 operates at 16 copies per minute.Good Luck!
Apr 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR5316 SHOWING PAPER WHILE NO PAPER JAM
try to chek if the actuator of the exit sensor is ok you will find it when you open the side door exactly attached to the heater try to check the end is it in plase or not if not use sim 30 sub1 to check all sensors you wil solve your problem
Mar 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar5316 blank pages printed and copied.
while standing in front of the copier open the Right door and then then flip down the Front door. Are the levers in place ? usually the front door will not close properly if not.
Second take out the toner and look for a loosely hanging piece of plastic on it, give it a tug, does it seem to be a long peice of clear plastic? if yes yank it all the way out. It is a protective piece sent for shipping. It will be on ALL the toners you get.
If not look at the right side door there is a back assembly there with either a black cylinder type roller or some strings.
Are the strings broken , is the roller in place?
Oct 25, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp Ar 5316 Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
