Question about Building Materials
My Essati/Neco electric garage roller door will not open further than 1/2 way. It will close but does not know when to stop.How do I reset the door ?
Posted by Andy on
mehan
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
If this door opener is getting old(over 10 Years) buy a new one. They very often fail and cost of repair exceeds the cost of replacement.
Posted on Apr 19, 2019
5 Related Answers
Anonymous
SOURCE: Garage opener/ brand garage master 1/3 HP
trolley is not attatced to the chain, grab that red rope that is hanging down and give it a ****. run the door up until it re-locks onto they trolley
Posted on Mar 30, 2008
Anonymous
  • 8 Answers
SOURCE: Craftsman 1/2 HP door opener bounces back open
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Posted on Sep 23, 2008
Door Tech
Joseph Chapman
  • 98 Answers
SOURCE: Garage door won't stay closed
Check the down limit:
 If the light bulb(s) on your operator are on the front and/or back, the limit adjustment screw is on the left side of the operator (looking from the back of the operator and facing  the garage door).. If the lights are on the sides of the operator then the limit adjustment screw is on the left side (looking from the back of the operator and facing  the garage door)
Posted on Jan 04, 2009
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: Problem with Sears Garage Door Opener
The motors is cought on something check the motor if it moves inches it will move a yard the question is the motor is it getting power? if so is it stuck on its own drive chain? Check these things you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 25, 2009
Anonymous
SOURCE: garage door squeak when closing
I had a similar problem and tried simlar fixes. Spraying the chain, the rollers, the track with silicon based lubricant did not good for my problem. My wife then listened carefully from where the squeak was coming. It was coming from the hinged in the actual door, the hinge like parts that allow the door to roll up. After we sprayed all of them, the sound just went back to the normal electrical / mechanical sound of the door opening and closing. I am sure our neighbors are happy too after 6 months of (very) early openings. Hope this helps.
Posted on Jun 08, 2009
My Essati electric garage roller door will not open further than 1/2 way following crashing into an object. It will close but does not know when to stop. How do I reset the door ?
Pull the red release handle to disengage the opener. Open the door with the remote. The door shouldn't move but the opener will operate. When it stops, physically open the garage door and push it all the way up. Now re-engage the release handle. GJiggle the door slightly to make sure the handle has engaged the opener. Now close the door. It should operate normally now.
Jul 25, 2016 | Building Materials
Fobs will not open or close roller garage door
Try to reset your fobs to work with the code of the control panel.
Jun 12, 2016 | Building Materials
Liftmaster GDO goes up 1/2 way and stops,springs are fine.
The Liftmaster openers have 4 movement switches, a )opening and b) closing limit and c) opening and d) closing force. First check the door for smooth operation by opening the door by hand (disconnect from the opener with the release cord). Any binding should be felt this way. It is possible for a binding hinge, roller or torsion springs to add too much drag and cause the force switch to shut off the motor. Hinges, roller shafts and torsion springs should be lubricated at least annually with a non oily spray (silicone or teflon spray). Not WD-40 or 3-in-1! A light band of lube should be applied to the torsion spring coils. If the door can be operated smoothly by hand, then adjust the closing force switch 1/4 turn at a time. This is a safety device do not use it to overcome another problem!
Aug 15, 2014 | liftmaster Garage Door 1/2 Hp
The down adjustment broke off
Check the micro switch that will be activated when the door reaches the closed position. It might need to be readjusted as it is supposed to be activated just as the door reaches the fully closed position to stop the further movement of the door. If it does not get activated at that point the door will try to open further but sence an "obstruction" and start opening again as a buildt in safety measure for protection against possible injury or damage to property.
Jul 23, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Genie trac drive
Over time, grime gets into the tracks, lubricant gums up in the rollers, and more pressure is needed.
On the ceiling mounted motor unit, there should be a pair of adjustment screws.
On my LiftMaster, they're labeled "OPEN FORCE" and "CLOSE FORCE".
These will increase the force exerted in the respective direction.
Make sure you are not adjusting the two screws that control the travel limit.
Adjust a LITTLE (like 1/8 to 1/16th of a turn at a time) and test before adjusting further.
Oct 07, 2013 | Building Materials
Garage door not opening properly.
Check the springs on your garage door. If one is broken, the opener will not have enough power to raise up and it will stop like that.Or the up and down limit settings have gone off or bad.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener does not reverse after hitting obstruction
release the door from the opener and see if door moves freely the check proper torsion by moving door up to 3-4 ft if it stays in this area torsion is properly set if not call technician to adjust torsion
if door does not move freely all the way up and down check for binding track alighnment and roller condition. the adjust closing pressure.
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
767 people viewed this question
Top Building Materials Experts
Tom Chichester
ray gallant
robert
Are you a Building Material Expert? Answer questions, earn points and help others
