The universal remote code for Astron TV can be programmed using the following list of codes:
672
673
075
094
091
000
0048
0042
0041
To program your universal remote to work with your Astron TV, follow these steps:
Aim your universal remote toward the Astron TV.
Press and hold the "SET" button until the small light on the remote control illuminates.
Enter the remote code using the numeric keys.
Upon entering the correct code, the remote light will turn off.
For Astron TVs, the Chunghop universal remote is recommended due to its compatibility and easy programming. Alternatively, you can try a GE universal remote, but you'll need to program it without specific codes.
If you encounter any issues with your Astron TV remote, such as it not working, consider resetting it to factory settings.
Check these codes: 0128 0013 0002 0071 0380
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Hello
Codes for Panasonic with Chunghop RM series remote control are:
0001/0003/0019/0037/0040/0106/0110/0111/0112/0114/0190/0212/0241/0711/0745/1036
If you are in need for a three digit code; remove the first Zero from each code and take the rest three digits.
Eg: for 0001 [four digit code] (001) is its three digit code. OK.
