Question about Cuisinart Food Processors
Cuisinart electric can opener won't open cans. Blade doesn't puncture can. how do I fix?
    Top Expert:
  • Cuisinart Master
  • 55,370 Answers
Replace it
Posted on Feb 09, 2017
6ya staff
SOURCE:
I have a Cuisinart with the blade that has been recalled. How do I get a replacement blade so I can use my Cuisinart again?
Cuisinart toll-free at 877-339-2534 from 7 a.m. to 11 p.m. ET Monday through Friday and from 9 a.m. to 5 p.m. ET Saturday and Sunday or online at www.cuisinart.com and click on Product Recalls at the bottom of the page for more information on the voluntary recall.
Jan 20, 2017 | Cuisinart Food Processors
How do I find out if my Cuisinart blade has been recalled? Model #DLC-7E
The simplest way to check if the DLC-7E blade is one of the recalled blades is to take the blade out and look at it. If there are 4 rivets holding the blades to the stem, it should not be used. For more information, look at https://recall.cuisinart.com/ .
I hope this helps.
(The rivets, if present, will visible when you look at the top of the blade where the two sections of the blade go around the stem of the unit.)
Jan 16, 2017 | Cuisinart Food Processors
What to do with Cuisinart processor #dlc-2007 that was recalled
Don't use it. Contact Cuisinart and they will send you a new blade. The recall is on the blade only.
Conair retira del mercado procesadores de alimentos Cuisinart debido...
Dec 14, 2016 | Cuisinart Food Processors
Cuisinart smartpower duet BFP703 food processor repair manual
Oh some of these answers... the most common issue with blender is that the removable blade unit starts to jam. So :
1. unscrew it, clean it and make sure it turns easy
2. open the unit and replace the fuse that blew up because turning the blade became too hard.
Voila
Nov 25, 2012 | Cuisinart BFP-703 SmartPower Duet Food...
I can't start my brand new cuisinart 14 cup model I have it plugged into a good power source, with shoot, rod and blade in place. It won't power up! Please help!
Hillary, I have the same problem. Do you think these are the edsels of the food processors. I paid almost $200 for mine, haven't ever used it since I bought it last year. Have you resolved your problem>
Oct 29, 2011 | Cuisinart DFP-14BC Custom Food Processor
My old mother has bought the Magimix 3200 but is not strong enough to open the lid once it is shut, actually most of the time I'm not strong enough. Can this be fixed?
Cuisinart Elite Food Processors don't require the twist action but the lid clips on, they are very easy to use with a number of great features including seal tight interlocking bowls, blade lock so the blade doesn't fall out when you're pouring out the results a pouring spout, plus a storage box for all of the blades:
http://www.cuisinart.co.uk/products-detail.php?ProductID=53&ProductCategoryID=0&ProductGroupID=1&DiscontinuedOnly=N
http://www.cuisinart.com/products/food_processors/fp-14dc.html
Sep 28, 2010 | Magimix 3200 Food Processor
Locked in blade
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
May 15, 2010 | Cuisinart DLC-5 Food Processor
Cuisinart DLC-7--blade stuck--cannot remove from bowl.
First off, is it a BLADE that's stuck, or a DISC?
If it's a disc, and the disc is blocking your access to the center post, put a ziploc baggie full of ice on top of the disc (right in the middle) and let it sit for about half an hour. That should shrink the plastic enough to pop it out.
If it's a blade, you can try the ice trick, or you can try Pam (or another food grade cooking spray) to loosen it up, and then just try to take the workbowl off like you usually would (aka, DO NOT grab the blade, or you'll risk cutting yourself--you can just pull up on the bowl, and the blade should pop off.
If you need further help, you can always contact Cuisinart--their phone number (according to their website, www.cuisinart.com ) is 1 800 726 0190
Good luck! :)
Aug 31, 2009 | Food Processors
Cuisinart mini prep processor blade not rotating
Replace work bowl and blade - see if it resolves the issue.
Oct 29, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
Food Processors Logo
430 people viewed this question
Top Cuisinart Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Colin Stickland
Colin Stickland
Bruce Showalter
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
