Question about Konica Minolta DiMAGE A2 Digital Camera
My dimage a2 wont turn on i tried 3 fullbaterys in it but it still will not turn on what can i do to fix this problem
I put full batterys in it. and tried hitting it 5 times on the top
Posted by Tavies on
3 Related Answers
Anonymous
  • 425 Answers
SOURCE: Is it possible to control DiMAGE A2 from PC? (when DiMAGE A2 is connected to PC.)
Yes, it is possible to control the camera from PC with "DiMAGE Capture DCA200". (sold separately) It is necessary to update the camera's firmware to use with the DiMAGE Capture. (the firmware is included in the CD-ROM attached with the product.) * DiMAGE Capture DCA-200 will be available at the end of March, 2004.
Posted on Sep 15, 2005
Anonymous
SOURCE: Konica-Minolta Dimage Z2 can't turn on
Well, I also bought the DiMAGE Z2, and my problem was similar: It worked for some time, but then it started freezing sometimes, not responding to any button I pressed. One time, it froze, shut off, and I wasn't able to power it up again. In short, the camera was still under its warranty, so I gave it to their lab and they fixed the problem.
Posted on May 19, 2006
elix0411
Jose Cada
  • 3530 Answers
SOURCE: I have a Dimage A2
Welcome to Fixya
"ERR" indicates an error with the camera body or the lens. Turn camera off, confirm the lens is properly attached and turn the camera on again.
If the above errors persists or appear frequently, please bring your equipment to any Konica authorised service centre for repair.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Jun 16, 2011
3helpful
2answers
I own a Dimage A2 and the viewfinder is very scratched. Can I buy one from anywhere?
In short, no. Spares are generally no longer available and expensive when they are.
But there are huge numbers of broken A1's and A2's which sell for near-nothing on auction websites which may be purchases as spares donors. The viewfinder lenses on both models are identical, although the actual electronic EVF display is different. Ask the right questions and buy wisely and you'll also end up with spare batteries and all the body covers which might have been lost from yours for no extra cost.
Wont turn on, low battery image flashing. I have charged the batteries.
Then check the battery contacts inside the camera are clean.
If that fails then replace the batteries as they do not last forever. Genuine Minolta replacements maintain their performance far longer than cheap generic ones (which often claim to have a larger capacity), but genuines are very expensive and cheapos are, well... cheap, and will need replacing far more often.
Minolta dimage 7i
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DONT FORGET TO RATE;
2answers
What are the available ISO rating for the DiMAGE A2?
The DiMAGE A2 sensitivity can be set to Auto, ISO 64, 100, 200, 400, and 800. When Auto is selected, the camera automatically controls the sensitivity within the range of ISO 64-200.
What autofocus modes does the DiMAGE A2 employ?
AF single or AF continuous can be selected. In AF single mode, focus is calculated and set when the shutter-release button is pressed partway down. This mode is mainly useful for a stationary subject. In AF continuous mode, camera continues to focus on a moving subject even when the shutter-release button is pressed partway down. It is convenient to capture the moving subject. When setting spot focus point in AF continuous mode, subject tracking can be used. (Subject tracking can be turned on/off by the recording menu. ) When selecting the Spot Focus Point, Full Time AF can be used*. * Full Time AF can be turned on/off on the setup menu. * Sensors mounted on the grip and on the eyepiece detect when the camera is held.
What is the external battery pack "EBP-100"?
This is the external battery pack used for the DiMAGE A1, 7, 7i,7Hi, 5, S414, S404, S304, Z1, Z2 and A2. This is the type of external battery pack that connects the camera and the battery part with a cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Two lithium batteries NP-100 Approx. 480 frames(recording), Approx.450 min(playback) Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Battery Charger BC100 is sold separately. INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
Is it possible to use the transformer when using DiMAGE A2 abroad?
The use of electronic transformers or travel adapters with this model via AC adapter or with the battery charger may cause damage to the product. Under these circumstances, we would recommend using the AC Cord which matches with voltage level of the country.
Konica Minolta DiMAGE A2 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Sheldon Dedek
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
