Manual is attached. You should be able to change the language setting in the 57 LM under settings/language and keyboard.
https://static.garmin.com/pumac/nuvi_57_58_67_68_OM_EN.pdf
SOURCE: How do you change the language from German to English
http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf
Page 46, follow the icon prompts to change to English. If this solves your problem, please come back and rate our solution. Thank you.
SOURCE: how to change language on a 255?
On the very first screen after the GPS boots there will be an icon of a
wrench at the bottom right of the screen. Press that Icon and scroll
through the menu and you will find a language setting.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Testimonial: "Thank you! Merry Christmas!"
SOURCE: Changing Language from Italian to English
If you want Italian, then the unit will show Italian. If you want it to show English, then you set it up for English. You can't have Italian verbal directions on an English unit.
To change the unit back to English:
Press Wrench.
Press the button with the picture of gears on it.
Press Down arrow.
Choose second menu item from the top.
Press the middle of the 3 boxes on the right.
Press up arrow to find American or British English.
SOURCE: i need to change the language on my my garmin nuvi
Garmin uses picture icons for most of the settings. When you forst turn the unit on you will see a magnafine glass map speaker and wrench. the wrench is tools press that. the next set of icons you will see another wrench that is settings press that. The next set of icons there will be a pair of lips that is language press that. The next screen is harder this is the language screen the upper left blue button is voice, the spoken directions, the upper right is text, the one you need to change, the lower left is keyboard. Select the text button, the languages are alphabetical so scroll up to american english, the screen will refresh then press ok.
The other solution is to do a hard reset. It sounds like you got this unit used or a floor model that someone changed the language on. It might be in your best intrest to reset to clear all saved info that others have input.
SOURCE: I bought a Garmin Nuvi
Setting the Languages
Voice Language--change the language for voice prompts.
Touch tools > Settings > Language.
text Language--change all onscreen text to the selected language.
Changing the text language does not change the language of user-entered
data or map data, such as street names. Keyboard--select the keyboard
for your language.
Touch Mode on any keyboard to change the keyboard
language.
