I am not sure about your "Boss", but a lot of vacuums have thermal cut-off switches built into the circuit so if the machine overheats from things like clogged filters/hoses the switch kicks in and kills power. You usually can NOT reset it manually ... you just have to wait until the machine cools down.
wiggle the cord while running the vac. if it cuts off from that, then you most likely have a bad switch or cord. if the motor was bad, you would smell it. it smells aweful.
Make sure it is not the electrical outlet that has tripped. If not then you basically have 3 choices. Cord, switch, motor. A service tech. should be able to diagnose.
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Had exactly the same problem with my upright Eureka Model 5893
bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking
to several repair men. Talked to Eureka, too, and they were absolutely
no help. Cheap wiring and switch made in China. Good luck trying to
find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis. It is Part #27871.
