SOURCE: no movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
SOURCE: little gem mobility scooter brake not working properly
The throttle part has slip round, a way to test this is to put hte buggy in reverse slightly and it shoud stop, meaning that how much the throttle has slipped round. Take the top cover off and there should be a allen screen on the throttle stem, undo and readjust.
SOURCE: 4120 eletc.hydrostat drive will not move forward
It sound like either the hydraulic filter is plugged or one of the safty switches have come undone, either by a break in the wire or a connector fauling off, anouther area to look is at all the linkage to make sure nothings has become dis-connected.finally check to make sure the belt driving the hydralic unit is within factory specs and tight enough. Hope this Helps Don
SOURCE: 1700 Fortress Scooter won't go forward or
Hi. Has the machine been in regular use before the fault occured? You say that the brake is in brake release mode, this mode is only ever used if you need to push the scooter by hand. It releases the brake on the motor, and also operates a switch to disable the controller from driving the motor. It does this because it would be to dangerous to drive the scooter with the brake disabled.
Move the lever back to its correct position. If it still does not work, then the disable switch might be faulty, or it might be a different fault such as a stuck brush in the motor.
Is this machine produced by shoprider ( Phisang ) of Taiwan.
Please let me know how you get on. Neil.
Either your parking brake is engaged or if your scooter is more like
mine i have a Rascal 600t it gives a code 5 service code when it thinks
its in free wheel. Your scooter is dropping into a fail safe mode and is telling you this by beeping. Most scooters have a service light on the tiller head that will flash out the failure code of the failure detected. Does your beep a number of times pause then beep this same pattern. The freewheel mechanism is located on the trans-axle
which if you go outside across grass it gets wet. This device doesn't
like moister and will get stiff will partially engage or disengage. In
that mechanism there is a micro-switch which if the lever when slipped
into the engaged position doesn't go all the way to the seated position
the switch will see the mechanism as being disengaged [in free wheel]
and will inhibit the motor from running. I lubricate the entire
assembly with pure silicon spray oil,WARNING, do not use WD-40, It will
eat some plastics.After lubricating the lever should move smoothly. I
have to lub my scooter about once a month in the winter.
Now if
this doesn't work check the connector that are all the wires are
connected. Disconnect the connector check the pins are ok reconnect
check to see if your still getting the failure. If you are still getting
this problem do continuity checks on the wiring. You will need a
multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Check the switch in the freewheel assembly. Select ohms the highest
scale, short the leads together, zero the meter by turning the zero
adjust knob. There is only one wire we are interested in. On some
scooters you can visually see the switch and the wire running from it.
The wire usually foes to a spade connector. Disconnect the spade
connector put a probe on that connector leading to the switch.
Disconnect the battery put other probe on the positive side of the
terminals that were connected to the battery not to the battery it
side.Work the switch does the meter needle deflect to zero, no, try the
negative side. Does the meter deflect, no, put the probes directly on
the switch terminals, does the switch.when worked now cause the meter
to deflect, no, replace switch, yes, the problem is in the harness,
don't panic, use can use that meter to trace the wire through the
harness. Wiggling wires and flexing connectors usually makes the meter
flick at some point. Thats how i do it i'm never without my trusty
meter. Rascal are notorious for having problems of this type my
mid-frame harness fell apart in the middle of a six lane intersection,
the scooter simply locks up tight .I can do nothing but sit in the
middle of this huge intersection. People try to move me but the scooters
wheels are locked, my illness makes it so i can't communicate with
people do it was a mess. So i modified the connector so its no longer a
latch type connector. I drilled it for a quick pin which is much
stronger than what its using now. Hope this helps
