Question about Blenders
My Ninja blender is stuck on the base. I've been using this for a year and this has never happened before.
Posted by Anita Wintzer on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Posted on Jan 01, 2008
Anonymous
SOURCE: Blender base gear knobs broke off
http://www.fixya.com/support/t509590-kitchenaid_ks85_coupling_drive
Reports the same problem and a couple of solutions.
Posted on Sep 26, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
Posted on Mar 21, 2009
Anonymous
  • 394 Answers
SOURCE: i have a waring
Hi I am Steve, lets get you some help.
I assume this is the retaining collar on the blender that you twist to release the top assembly rather than anything else.
It could just be out of alignment and gently shaking the bowl whilst applying a pressure to the collar may clear whatever is causing the jam.
Posted on Feb 06, 2011
Anonymous
SOURCE: Ninja blender second time
Put the lid on so the arrows meet up. There is a arrow on the lid and handle put them to gather and blend!
Posted on Mar 05, 2012
2answers
Why won't my ninja blender turn on? The red light is blinking, but power is connected and lid is secure.
try rotating the container part 1/4 of a turn to line up slots and press down . then if it does not blend turn another 1/4 turn to line up slots and press down pushing container into base motor unit .
container and screw on blade lid is put in upside down and the plastic posts have to match the base unit to turn on the blender when you press down on container into base unit.
I own and use a ninja blender !.
May 08, 2018 • Blenders
2answers
Why does my ninja blender power light blink red
-Make sure the lip is closed at the correct position and press down to lock before it let you turn it on.
Good luck
Mai
How to remove splash guard from base
Good evening
it is difficult to take the bottom things from each other. The blenders I know are screwed to each other,
all the best
kolbrun
Where do I find lids for the nj600 blender
Ninja Professional Blender . if this link works it will show the lid for the blender. If the link does not work, do a web search " Parts and accessories-Ninja. On the top menu, click on parts and scroll down to Ninja professional blender nj600 and click on it.
Single serve ninja cup stuck in base
IF YOU ARE ALREADY STUCK: Find the tiny detention/release "button" in the grove at the back near the top of the base unit. Use a butter knife or the back of a sharp one to slide the button DOWN toward the counter (not in toward the blender blades).
TO PREVENT THE PROBLEM: Look at the 4 locking tabs on the single serve cup. They are rectangular with the lower right corner HEAVILY beveled (when viewed broadside). The solution to the problem is to LIGHTLY bevel the upper left corner too. I used a pocket knife to shave just a little bit off at 45 degrees. Proceed carefully one tab at a time testing it in the rear slot. Shave just enough to get an easy release. Shave all 4 tabs on the cup so it doesn't matter which one is inserted in the rear groove.
9helpful
Unable to fit. Cup into base of rocket blender
I had this exact same problem and was scratching my head why would that happen all of a sudden. After taking it completely apart (which I didn't need to), I realized in the end that the cup rim was stuck at the bottom of the blender base. It looked like a part of the base what got me confused the first place. The base of the blender is flat with no ridges around; check if this is the same problem with yours.
Blenders Logo
Top Blenders Experts
ADMIN Canada
ADMIN Canada
ray gallant
Tom Chichester
Are you a Blender Expert? Answer questions, earn points and help others
