Question about Curtis Televison & Video
3 digit curtis tv remote code to use with Spectrum cable
Posted by marlon on
Electro Med Services
  • Curtis Master
  • 6,694 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
http://electro-medical.blogspot.com/
Posted on Feb 08, 2017
5 Related Answers
Anonymous
SOURCE: QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
Posted on Mar 29, 2008
Anonymous
  • 133 Answers
SOURCE: Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Posted on Jul 06, 2008
Anonymous
SOURCE: Remote control codes for general instruments cable box
i have a curtis mathes tv called an itronics and i need a remote controll code for it
Posted on Aug 14, 2008
Anonymous
SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
Posted on Oct 29, 2008
muebe
  • 1015 Answers
SOURCE: Missing CD-ROM & cables for Curtis Digital Camera Model# DCD5159
Well it appears that Curtis has discontinued all support for this camera. You might be able to obtain a USB connector that fits the camera online. Most use the standard/micro USB connector. As far as drivers if Curtis does not have it on their site then they might be tough to find. If you are using Vista the it might recoqnize the camera and install drivers automatically. If the camera has removable memory card you could remove the card after taking the pictures and put in the SD port of the computer and transfer the pictures onto it.
Posted on Sep 19, 2009
Testimonial: "Thank you Muebe, Your advice is very helpful. I'm glad you're out there. Mike Lore"
Remote code to re-enter stations
I believe this is a tv question although in the car audio category. I apologize in advance if it is not.
Codes are generally consistent within brands but not between brands. That tends to mean one has to know the brand and model of the remote and brand and model of the tv. However, I have links to A. Universal remotes B. Spectrum remotes C. DirectTV remotes. Here goes:
4 Digit Universal Remote Codes For TV Codes For Universal Remotes
http://www.spectrum.net/support/tv/charter-remote-controls-1060bc21060bc3
https://www.directv.com/DTVAPP/content/remote_codes2
I have a universal remote control that I want to use with my Curtis Mathis TV. What code do I need to use to make the remote compatible with the TV?
Hello
Thee digit universal remote code for Curtis Mathis are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote codes for Curtis Mathis are:-
0031 0105 0130
0004 0009 0000 0049
0109 0358 0001 0015
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Hi. Can you please tell me the correct code for the Curtis tv for Cablevision Remote? We have two remotes now, the cable remote cannot operate the volume or the power on/off tv, must use Curtis remote.....
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
Need code for Cable remote to work tv
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
1helpful
3answers
Curtis LCD1575 15" lcd tv
You might need 4-digit codes if your remote is older and only does 3-digit codes. Here's the code list:
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
Codes
I have found some Curtis codes you can try. 00, 06, 11, 15, 21, 50.
If those do not work, does the cable remote have a "learn" function?
This is where you point the cable remote at the TV remote face-to-face & press all of the pertinent buttons on TV remote in order for the cable remote to "learn" what codes th e TV remote is generating for the various control functions. If the cable remote does have this function the users guide will give you step-by-step instructions. Barring that contact your cable provider.
Keep in mind that there are so many TV models being produced by numerous manufacturers these days that it maybe possible that your model's remote codes are not compatible with anything than another Curtis product. You may have to contact Curtis directly.
Televison & Video Logo
Top Curtis Televison & Video Experts
Abhinandan  Patil
Abhinandan Patil
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
