Question about Samsung ML-2510 Laser Printer
Samsung 2510 printer keeps running and won't stop
Posted by Blair Barrett on
5 Related Answers
Anonymous
  • 12 Answers
SOURCE: My samsung 2510 lazer printer
Did you install the printer software and what error lights are on?
Posted on May 19, 2008
Anonymous
SOURCE: my ML-2510 samsung printer stopped printing?
Delete printer Icon in the "printers and faxes" dialog box, then use the software installation Cd to re-install it. Also, depending what software that printer uses, there may be a "Samsung" software to delete in "add/Remove programs" in the "control panel" as well. I would delete everything and start from scratch.
Select the proper port when setting up. I assume you are using a "USB" port?
Posted on Mar 16, 2009
Anonymous
SOURCE: Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Posted on Apr 18, 2009
Anonymous
  • 59 Answers
SOURCE: Samsung ML-2510 Installation Problem Windows Vista Home Premium
wellcome in fixya .com
please click on this link where u can find the driver of samsung ml-2519 for vista
Posted on Jul 29, 2009
Anonymous
SOURCE: Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Posted on Apr 27, 2010
My Samsung laser printer ML-2510 keep wont stop running (two lights are blinking same time) until I manually turn off the switch.
After removing the pickup rubber (and not removing the rubber band from it's plastic drum) I cut a thick piece of card stock paper the width of the rubber band and slid it under the rubber. I thought it would make it contact the paper with more force and it worked great.
Dec 04, 2011 | Samsung ML-2510 Laser Printer
RED LIGHT KEEP BLINKING ON MY ML-2510 PRINTER IT STILL WORKS , WHY?
A red blinking light on a samsung printer will often indicate that your toner level is low. It will still continue to work until the toner fully runs out. This is Samsung's warning saying that you should think about changing your cartridge soon. I hope this helps.
Sep 08, 2011 | Samsung ML-2510 Laser Printer
Jul 29, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 will not print from MAC OS on Macbook
This printer has problems with Leopard last updates.
Contact Apple to see if a patch is available to run the printer on updated Leopard:
Apple - How to Contact Us.
Regards.
May 23, 2009 | Samsung ML-2510 Laser Printer
My ML-2510 samsung printer stopped printing?
Mar 15, 2009 | Samsung ML-2510 Laser Printer
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
ML-2510 mono laser printer / samsung
the answer is on:
fixyourownprinter.com
May 09, 2008 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Logo
250 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
