Since brand new, epson stylus photo R280 intermittently (3 times in a year)shows low ink level in light magenta cartridge and stops working then the problem disappears inexplicably after a period of turning it off and on, unplugging it, blowing compressed air on the cartridge/machine contacts
Try using a soft cloth saturated with rubbing alcohol over the metal contacts. Make certain all residue to include spent ink or oil from your fingers have been removed. Let air dry. If your printers Print Head can be removed separately, that is the way to go when cleaning components. It has been known that Print Heads fail also and need replacement.
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
SOURCE: Clogged Epson Stylus Photo 2200
Well you certainly covered all troubleshooting that needs to be done and if head cleaning can´t do it -> you got to open it or have it serviced.
SOURCE: Epson Stylus R230 Light Magenta Not working
I would recommend cleaning the contacts (brass colored connections) with an eraser if might resolve the issue. It that does not resolve the issue it might be one of two other things. Either the printhead is cloged or the cable to the printerhead is damaged.
Good luck
SOURCE: HELP !!!! Instantly empty INK CARTRIDGES Epson Stylus Photo R1800
Hi
What i can recommend is call epson and tell them about this issue and for sure they are going to replace the ink and will run diagnostic test on your printer- here is there support line number 562-276-1300
SOURCE: Runtime Error
Try this link:
http://support.microsoft.com/kb/178385/en-us
and install the executable file that you can find in this link
http://download.microsoft.com/download/streetstrips2000/utility/1.0/win98/en-us/runtifix.exe
When you get the error and click on details, what is the exact error that you see?
