SOURCE: ksrg25fkss kitchenaid refrig door needs height adjusted up
Have you looked at the mounting bracket for the lower hinge to see if it can be adjusted up. If not and there is as mush as 1/4 to 1/2" adjustment i suggest that you get a spacer with the inside diameter the same as the hinge pin or a tiny bit bigger and cut it to the size you need , then support the door up to a point that the bottom pin is not bound, remove the lower bracket and hinge pin, put the sleeve you cut on the hinge pin and reinstall the bracket.
SOURCE: my kitchenaid ksrg25fkss refigerator supera wont get cold
freon. dirty coils under refrig. fan motor by comp. not working. make sure first of all comp. is running if not make sure freezer fan is. if that the case you need a relay starter overload or a compressor.
