Normal 0 false false false MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Yes, it is something to do with Firewire. I managed to dothis with my Canon MV750i so I know it can be done!
You are correct; the USB cable only transfers pictures from the SD card. To transfer video from your camcorder to a computer you need to use a Firewirecable (also known as IEEE 1394), and you need to have a socket on your computerto plug the Firewire cable into. Macs already have a socket built in butgenerally with PCs you will need to install (or get someone to install for you)a special card with the Firewire socket on it.
I can't explain the whole procedure here but you can getstarted by looking at the following articles on the Canon website. Thefirst one explains what sort of connections can be made on different Canoncamcorders (including the MV730i) and what you can do with them:
http://www.canon.co.nz/products/digital_video_cameras/home/mv730i.aspxThe second briefly explains what hardware and software youwill need, how it goes together, how to make DVDs and so on:
http://www.canon.co.nz/support/customer/default.asp?DXI=KnowledgeBase/Customer/KBArticleForm&File=KB01213&productID=mv730iUnfortunately there is no quick, simple answer but I hope thispoints you in the right direction!
