Question about Apple iPod Audio Players & Recorders
Does the I-pod shuffle need to be turned on when plugged into the usb port and also when it is plugged in the yellow light blinks ? When I check battery status , it says 25% ?
6ya staff
SOURCE:
Anonymous
SOURCE: TV won't turn on.
Lamp is bad need new lamp
Posted on Apr 27, 2008
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: Canon Pixma iP2000: yellow power light blinks-reset doesn't work
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Anonymous
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
SOURCE: Cannot turn my i pod touch on
your ipod seems to be having problem like damaged system software. you can reinstall your ipod software but will erase anything on your ipod, don't worry you can sync them again. here's how to do it.
make sure itunes is open and connected to the internet.
Hold down your ipod power button, then hold down the home button too, this will force the ipod to restart and in restore mode.
the screen will go dark and restart, now release the POWER BUTTON while still holding down the HOME BUTTON.
It will show an itunes icon and a USB icon saying connect to itunes.
NOTE: you might have to do this procedure many times in order to show the itunes and usb icon.
Now release the HOME BUTTON and connect to itunes, it will erase your ipod and download software from apple to install on your ipod.
this might take some time, wait for it to complete the task and now you are ready to use your ipod again.
Please rate. Thank you
Posted on Sep 17, 2009
Wen i connect my i pod to computer it does not connect
Check to see whether your iPod shuffle is the original stick version or the newer version, which plugs into the iPod dock connector.
Turn your PC on.
The PC needs to be on to transfer music and charge the iPod shuffle.
Place the iPod shuffle in the iPod dock connector if you have the newer version.
If you're using the original version, then plug it directly into a high-power USB port on your PC.
Check the monitor to ensure iTunes has loaded.
This means a connection was established.
hope this helps
Oct 11, 2012 | Apple iPod shuffle MP3 Player
How do you charge an ipod shuffle
Connect the included USB cable to your iPod Shuffle.
Plug the opposite end of the iPod Shuffle cable into an open USB port on your computer, which must be turned on.
Check the light on the iPod Shuffle. If the light has turned on, the iPod Shuffle is properly charging.
Using iPod charger
Plug the iPod charger into a working electrical outlet.
Plug the opposite end of the iPod Shuffle cable into the USB port on the iPod charger.
The iPod Shuffle should begin charging immediately.
hope this helps
Sep 18, 2012 | Audio Players & Recorders
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
2nd gen ipod shuffle won't recharge- blinking orange light only
you need itunes to listen to the music on your ipod throughyour computer
Aug 30, 2009 | Apple iPod shuffle MP3 Player
"Lost" all USB ports on win xp laptop after plugging ipod shuffle
go into the system restore and choose a date when the usb ports were working then let it go thru its process of restoring. It will restart and then test the usb ports then, if you still can't get them to work then that means the motherboard is bad.
Jun 30, 2009 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Ipod shuffle 2nd gen problem
Remember these five basic suggestions if you have a problem with iPod shuffle. Try
these steps one at a time until the problem is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
Reset iPod shuffle by turning it off, waiting five seconds, and then turning it back on
again.
Retry with a different USB port if you cannot see iPod shuffle in iTunes.
Restart your computer, and make sure you have the latest software updates
installed.
 Reinstall iTunes software from the latest version on the web.
 If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
 Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
Turn iPod shuffle off, wait five seconds, and then turn it on again.
You may need to restore iPod shuffle software
May 31, 2009 | Apple iPod shuffle Second Gen. Silver (1...
My iPod shuffle will not charge
If iPod shuffle won’t turn on or respond
â If the status light blinks orange when you press a button, the iPod shuffle buttons are
blinks green.
â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
â Turn iPod shuffle off, wait five seconds, and then turn it on again.
â You may need to restore iPod shuffle software. See “Updating and Restoring
iPod shuffle Software” on page 26.
Jun 25, 2008 | Apple iPod shuffle MP3 Player
IPod shuffle 1st gen. Not Recognized By PC
Try a different USB port first. Here are some other suggestions:
Connect iPod shuffle to a high-power USB port on your computer. iPod shuffle may
â Make sure you have installed the latest iTunes software from
www.apple.com/ipod/start.
â Try connecting to a different USB port on your computer. Make sure iPod shuffle is
firmly seated in the dock. Make sure the USB connector is oriented correctly. It can be
inserted only one way.
â iPod shuffle might need to be reset. Turn iPod shuffle off, wait five seconds, and then
turn it back on again.
â If there is no status light (or the status light is dimmed) and iPod shuffle doesn’t
appear in iTunes or the Finder, the battery may be completely discharged. Let
iPod shuffle charge for several minutes to see if it comes back to life.
â Make sure you have the required computer and software. See “If you want to doublecheck
the system requirements” on page 25.
â Try restarting your computer.
â If none of the previous suggestions solves the problem, you might need to restore
iPod software. See “Updating and Restoring iPod shuffle Software” on page 26.
â If restoring iPod shuffle doesn’t solve the problem, iPod shuffle may need to be
repaired. You can arrange for service on the iPod shuffle Service & Support website at
www.apple.com/support/ipodshuffle/service.
Jun 09, 2008 | Apple iPod shuffle MP3 Player
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
