SOURCE: rear brake cylinders are stuck, can not push them in
I have a 2004 SAAB 93 and just finished replacing the brake pads and rotors yesterday. On the piston itself you should have two little notches. You can either or a GM rotor reset tool that will push into the two little notches and push against the piston while rotating it clock wise. Or the way that I did it was to take a C clamp and put the caliper back on the car. Clamp it on the back of the caliper to the front of the caliper so it will remain stationary. Then take a pair of needle nose pliers and rotate the two notches clockwise while pushing into the caliper. It will take some strength but you should be able to push them in. Be sure that you spray the boot around the piston when some WD 40 so it does not crack and or break during the process. If you have any additional questions about this feel free to email me.
James
[email protected]
SOURCE: CHANGING REAR BRAKE PADS
the best thing you can do is go to an autoparts store and purchase a haynes repair manual for your car. cost about $18, but will show you everything you need to know, with pictures.
SOURCE: 2005 malibu rear disk brakes
I didn't have a "cube tool", used a pair of channel locks. Worked great. Thanks.
SOURCE: Jeep Commander Rear Brake Pad Installation
Per Chilton Auto repair manual:
Removal & Installation
To install:
WARNING
Support the brake caliper with mechanics wire. Do not let the caliper hang by the brake hose.
SOURCE: How To Change Rear Brake Pads on Audi A6 2006
Remove the tires, Remove the calaper bolts, (small heads on them 12mm or so) Remove calaper, Pads are setting in a holder. Lube new pads with litheum grease and place in holder. (look at old pads, one or both may have small metel tab on one end) If the new pads have the tab, put that pad where the old pad with the tab was. (ie. tab to the inside) Press pistion in with a 'C' clamp. If it won't go in easly, it may screw in. If the parking brake cable is hooked to the calaper, it probly screws in. Use large pliers to screw in calaper piston. Place calaper over pads and install bolts (lube bolts) Rember to pump brakes befor driving . to get a solid peddle.
