Question about LG WM3987HW Front Load Washer / Dryer
Washer leaks but onlyu during drying cycle - LG WM3987HW Front Load Washer / Dryer
Posted by Joe Graham on
marley mcelhinney
  • 490 Answers
The main drama i have with these lg washer/dryers is the drying vent blocks up with lint which causes excess heat build up around the heater and it often results in a small hole melting through the front tub under the heater vent where it joins to the plastic tub, it also results in water leaking out the melted hole when it dries but not during the wash as the hole is at the top of the tub, parts are relatively cheap for what they are but its a massive job to replace the front tub.
Posted on Feb 06, 2017
Supra washer/dryer combo leaking significantly
In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
2answers
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
1helpful
During the wash cycle of the 24" combo washer dryer, it leaked
A hose inside the washer is your most likely culprit. On older whirlpool washers they used a plastic hose to run from the pump to the back case of the machine that was pretty susceptible to cracking.
1helpful
My ZWD1471 started leaking during the drying cycle recently. It doesn't leak during the wash cycle. The water seems to be coming from underneath the back of the machine, I think on the righthand side. Any...
open it and see where the leack come from it might be the drain pump and it easy to replace or it might be a hose that got burst...
see if you can open it from the back or the bottom front
Washer leaks from bottom during rinse cycle
Take the cover off the back, and look up, next to where you put the soap in, when it's filling/rinsing. There is (like) a (white) plastic valve body, and look to see if water is dripping out of it. I haven't figured out a solution to that yet, other than to replace it.
Also check the boot, coming off the pump. You could have a bad/dry boot, or a loose hose clamp.
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Leak during tumble cycle
more than likely that the seal for your condensing chamber has become faulty easy fix undo any screws that hold the condesing chamber on get some bath/shower sealant that is waterproof put this around the chamber and put it back on you will have to leave it for a couple of hours but this should fix the leaking problem its not totaly common but this does happen m8
LG WM3987HW Front Load Washer / Dryer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
