My washer is overfilling then stopping and showing "LF" on the control panel. I have to hit the power button for the washer to empty. My husband replaced the water level sensor but that did not solve the problem. Any ideas as to what we can do to fix this ourselves? Any advice would be appreciated. Thank you
SOURCE: maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Retry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: How to install a new temp sensor Whirlpool electric water heater
The instructions for installing the sensor will probably included with the new part. Also, when you receive the part and actually see it, you will probably know where it will go. Sometimes, things like this happen even with new units. I have had bad thermocouples on brand new units right from the factory. It happens and unfortunately it happens to us sometimes. Good luck and if you get the part and still have trouble, contact them again. If you would have bought a GE (Rheem) unit, they would have sent a tech out to your house at no cost. I'm not a fan of Whirlpool water heaters.
if you are mechanical and are not afraid of small wires you can try this. I had the exact same problem on my machine. i very slowly diasssembled the machine. not hard to do. removed the top. unscrews from the back and slides to the back to come off. remove the door. unsnap the plastic plate that goes around the door.it is held on by small snap clip that pop off if you use a small flat screw driver to pry it out. remove detergent tray. and screws that attach it to the inner box. now the hard part. remove the face plate. it unsnaps similar to large door plate.very carefully unclip the circuit boards. they are held in by plastic clips around the outside and white plastic clips in the middle. you must gently pry up and release these clips one at a time. a second person is helpful, so are small needle nose pliers. clean both circuit boards very gently with isopropyl alcohol and qtips. mositen the qtips and clean every inch of the boards. be very careful not to bend or crack anything. you must get all the yellowish flux and any other corrosion growing on the board off. there is one more board that must be cleaned. the power supply board. it is mounted on the top right side near where the face plate wire come through. this is not hard to remove it is held in by small clips. the tricky part is the wires. they are all designed so they cannot be plugged in incorrectly but i have seen what people are capable of. make a map. number them with a sharpie so you know where they go. remove this board and clean it the same way. this on will probably be the worst offender. i cleaned all the boards reassembled and it works like new. below the door is a panel that should also be removed. there is a removable drain filter that should be cleaned out. i found pens and toys in mine. the machine could not pump out the water fast enough and would shut down and trigger f70 and f 20 codes.
SOURCE: overfilling Whirlpool cabrio washer
Great! It may be the water level control switch. So, where is it and how do you check it or fix it or replace it?
SOURCE: F28 code washer stops working. Reset will only
Error code F28 indicates that one of the below part is bad
If you find either the MCU or the CCU(Microcomputer Machine Control
Unit) you can fix it,
Here's the online repair manual for Whirlpool Duet Sport, but its identical to your HE2.
Refer page# 4-20 it describes how to get to MCU.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Testimonial: "I'll look for that manual-thx for the info"
