Refrigerators Logo
v
vered rahimi Posted on Feb 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have sharp refrigerator. It has 4 doors. The upper refrigerator not working. The freezing down is O.K.
Model: sj-x5403msl
Electro Med Services
Level 3:
  • Sharp Master 6,694 Answers
  • Posted on Feb 04, 2017
Sharp Master
Level 3:
Answers
6694
Questions
Helped
1872548
Points
21433
If you wish to get some details about refrigerator repair check the following link ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Sharp SJ-F80SP Four Door Refrigerator. I have an SJ-F80SP-SL, the freezer is working but the fridge is not. The light is on.
Question edited for clarity, and add maker.
It may need a top up of refrigerant gas, but first check that the circulation fan in the fridge is working. Also make sure the condenser coils are clean.
2answers
I have a Sharp Fridge-Freezer, model SJ-F78SP-BK. The Fridge compartment freezes. If left on overnight, everything will freeze as if it had been left in the freezer. Freezer is working fine.
please increase the temperature in the fridge portion of your fridge as it sounds like you've set that compartments temperature too low.
Thank you.
1helpful
Sharp model SJ-F78PE-SL fridge part not working
call your local repair service . sounds like the air damper control may have hic ups
1helpful
Sharp SJ F60PC SL refrigerator-freezer is freezing the refrigerator compartment.
I would take a look to make sure your coils are not frozen or covered with ice on the inside of the fridge on the back wall and also double check the drain line on the back.
You could have a faulty switch that controls the thermostat as well.
I have a sharp 4 door sharp sj-f65ps. The ice builds up in the freezer and the fan makes noise as it hits the ice, ice cubes melt and the temp goes down, i have been defrosting manually every week....
You need to figure out which component in the defrost circuitry is bad. Either defrost element, defrost thermostat or defrost timer/control If the element and thermostat show 0 resistance it's the defrost timer/control board
My sharp freezer model SJ-229S-SL , UPPER IS WELL BUT BOTTOM NO COLD
Checked Damper in Ref its working or not. You can checked open Ref door press Door Switch and hold your hand near chiller tray Duct
Top Sharp Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
