Question about Coby TF-DVD7107 Portable DVD Player
CHARGING I CANT GET MY DVD PLAYER TO CHARGE. WHAT DOES THE RED LIGHT MEAN WHEN PLUG THE CHARGER IN? IT USED TO BE GREEN BUT NOW ITS ONLY RED.
Posted by LULU1121 on
  • Anonymous Nov 26, 2007
    I hAVE THE SAME PROBLEM. i CHARGE IT OVERNIGHT AND THE BATTERY WORKS FOR 20 MINS THEN DIES. i CAN ONLY USE IT WHEN IT'S PLUGGED IN.
Anonymous
  • 52 Answers
Lulu1121 and guest, red means no charge and will remain red till its fully charge. Then it will turn to green. In fact, coby battery can be charge directly without the whole unit attached. But if on charge too long and still red, battery is dead, kaput, finish. some even show evidence when the casing is swollen...gel chemicals inside is swollen. The power supply that came with it is the only way you can use it...portability is out of the question.
Good Luck
Siliconchip
Posted on Mar 02, 2008
I would like to use my snowblower for the season. I've never used before, my husband used to do it. He said that I need to charge it first before using it. How do I go that
hopefully you will find the charger near the machine ? ( a plug with a lead ) simply plug it into an electric outlet ( plug hole ) and connect it to the blower ( you will see a hole in the blower the same shape as the end of the lead on the charger) if the charger has lights on it ( usually red and green ) you will see the red light come on,leave it charging until the green light comes on. or charge it over night...hope this helps
Nov 19, 2015 | Garden
I recently puchased an EGET MO-H04CD portable oxygen concentrator and I am having problems charging the Lithium batteries that were supplied with the unit. There are no instructions on how long you have to...
Red light normally means that the battery needs charging. The green flashing light can mean the battery is charging or has charged, and the same with the solid green light. Green in this case is good.
Charge the unit overnight and see what the indicator state is. It should not take more than 8 hours of charging for a Li-ion battery. Once you know what the full state light looks at, then you can tell what the charging indicator looks like.
In all cases, ensure you are using the proper charger with the unit.
May 14, 2011 | Health & Beauty
I NEED A NEW RECHARGABLE BATTERY FOR MY PVS1080 I THINK IT IS THE BATTERY... LIGHT ON THE CHARGER FOR POWER IS RED AND THE CHARGING LIGHT IS GREEN BUT BATTERY DOESN'T CHARGE.
But u if plug in the A/C power adaptor charger in the DVD player still work?Could be the A/C power charger adaptor itself have problems too.Yes,than it is the litium battery not taking any more charges.Tries website like Amazon.com,Ebay.com to buy a new exact litium battery or a compatible one.These websites should have A/C power adaptor charger too.
Feb 01, 2011 | kawasaki PVS1080
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
CHARGING A COOL BATTERY PACK
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
Need to know what the lights mean on a makita dc24sa charger
• When the battery cartridge is inserted, the charging light color will change from green to red and charging will begin.
The charging light will remain lit steadily during charging.
• One red charging light indicates charged condition in 0 – 80% and two red ones indicates 80 – 100%.
• With finish of charge, the charging lights will change from two red ones to two green ones.
• The charging time is as follows:
Battery B9017A, BH1220, BH1420, BH9020A: approx. 20 minutes.
Battery B2417, BH1233, BH1433, BH2420, BH9033A: approx. 30 minutes.
Battery B2430, BH2433: approx. 60 minutes.
Nov 20, 2008 | Makita DC24SA 24 Volt Makstar Battery...
Charge
Charging the Player
The player needs to be charged before it can be used and every time
the battery gets low. It takes approximately 2.5 hours to charge the
Player. Once fully charged, the Player lasts approximately 8 hours.
To charge the Player:
Remove the USB cover on the Player.
Connect the Player to the PC using the Flash Plug.
The Player will begin charging. The battery indicator should begin
to flash, alternating red and green.
Once the battery is fully charged, the indicator light will stay red.
Note: If this is the first time the Player is connected, wait until
Windows detects the Player and follow the prompts to install it.
Mar 15, 2008 | Disney Tink Digital Mix Stick MP3 Player...
Coby TF-DVD7006.
The second question, I couldnt work that one out at first, but now i think I understand. If you plug the player into the mains, turn it on, red light shows. Light turns green when battery charged. Do not use until light turns green (if plugged into mains). In other words dont use the player while the battery is charging. If it isnt plugged into the mains then the battery cant be charging and you can use. Until battery gets too low :)
Nov 13, 2007 | Coby TF-DVD7006
Battery won't charge
clean the contacts of the battrey and the charger.if that does not work replace the charger or the battery.goodluck.
Apr 03, 2007 | kawasaki PVS-10921 Portable DVD Player
Coby TF-DVD7107 Portable DVD Player Logo
271 people viewed this question
Top Coby Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
