Ovens Logo
Question about Neff Ovens
Multi purpose oven won't work after power cut have reset clock, light won't work. Is making all the right sounds just won work
Posted by Caroline Kavanagh on
Anonymous
Power supply from clock damaged not by power cut but voltage spike when power resumed the oven thinks its in auto mode permanentley thats why it wont come on ,new clock or power board needed.
Posted on Mar 04, 2017
After a power cut in our area my camberley double oven clock continuously flashing in the auto mode how can i stop it flashing and get my cooker working again.
First I would say to unplug it wait a couple seconds and plug it back in case it got a power surge from the power going . Then reset the clock! Right now it's set in a power saving mode until you do the steps above!
Oct 03, 2019 • Ovens
I have reset the clock the oven sounds as though it's working for just 2 seconds and then stops. The light will not come on at all. I have cleaned all contact points still no luck .
inverter failure blows safety fuse internally this will power down the oven to prevent further damage new inverter and fuse needed.
Feb 03, 2017 • Neff Ovens
Hotpoint oven bs43
you need to send the full model number,most likely you have a bad clock assy.even though your clock might work it comes with the clock and a computer board all together.i never heard of resetting a timer,i do know that if you unplug or shut down the power from the fuse box for 5 to 10 minutes sometimes resets the computer just like a regular house computer, it sounds like your loosing power and i don't think resetting anything is gonna help you,also make sure you have 240 volts going to the oven,but if the fan and light are not working and no heat it sounds like you have a bad clock assy.if it's in good shape and depending on the age you might want to call someone in to check it for you,if it is the clock assy. it might not be avalable anymore but there are companies that can rebuild the clock assy. you have.good luck with your oven.
Jul 10, 2013 • Ovens
I HAVE A GENERAL ELECTRIC (WALL) OVEN MODEL #JKP13G.. WHEN IO TRY TO PREHEAT THE OVEN TO BAKE SOMETHING IT LIGHTS UP TO ONLY ABOUT 100 DEGREES (BUT DOESN'T GET HOT AT ALL( AND THENIT JUST CUTS OFF. ...
if the clock is cutting out on you it sounds like the computer board or clock assy. same thing is bad but this oven is to old and you can't get the board anymore,it's to old and they don't make parts for it anymore,get a new oven
Nov 08, 2017 • Ovens
1helpful
We had an electrical power cut for a few seconds and the the power came back on i checked every thing was working except the large and small over the lights do not work,the grill is okis there a fuse just...
I think I know what you are talking about, your text is a bit jumbled. If there is a electronic timer/clock it sounds as if it has reset to auto. mode with the power outage. It needs to be in manual mode for the ovens to work.
Feb 18, 2011 • Ovens
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't...
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
I had a power cut and it only lasted 8 mins my cooker works top oven works but the main oven doesnt how do i work it as the fan and light works but oven do not thank you
If you have had a power failure, you may find that the clock has reset. If the clock has an auto setting this will be linked to the main oven only and therefore the clock will need to set to manual for the oven to work. The alternative is that the oven element has blown and this is what tripped your power, in which case you will need to replace the element. Hopefully, the first scenario is correct and will be a lot cheaper.
All the best, pls leave feedback or reply for further assistance with make and model number.
Aug 20, 2010 • Ovens
We had a power cut yesterday and today my neff electric oven just shut down completely. The clock has also stopped working.
if you have power to oven but the clock is not working it sounds like overvoltage has damaged the clock if clock will reset and you can set the time oven will work.
Oven has power but will not turn on. Cannot set
try to cut the power to the oven for about 30 minutes and see if it will reset the clock. if this doesn't work you may need to replace the ERC (clock). sometimes you can get a rebuilt, check around.
Oct 11, 2009 • Ovens
Power cut and now cant reset the clock
We flipped off the designated breaker to the oven and turned it on again. We were then able to reset the clock. This has happened to us several times.
Top Neff Ovens Experts
Paul Carew
W.L.
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
