Question about KitchenAid Kitchen Appliances - Others
Kitchenaid kettle not switching on. The base lights up when putting the kettle on but then just starts flashing and nothing happens
Posted by Colleen on
William McMaster
    New Friend:
Kettle blow electric of when switched on now it's not working could it be elements thank you
Posted on Jun 07, 2019
Carl Rock
  • 3,099 Answers
It's the manufacturers way of telling you, the appliance you love and use everyday has been rendered useless (by liability protection circuitry). Return for warranty repair/replace.
Posted on Feb 06, 2019
Problem with soup mate,all lights flashing but nothing happening
If this is a Kitchen Aid blender with the flashing lights then you will need to remove the motor base cover and check the motor for a circuit. If it is open circuit then either replace the motor or locate the thermal fuse (under some white tape and aluminium clip on one of the field windings) and either replace or bypass fuse if it is open circuit.
May 19, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Aroma AWK-161 Water Kettle not turning on
A power outage happened and all of a sudden Aroma kettle was not turning on. I tried different outlets that I knew worked... nothing. So, problem was certainly the kettle. I gave some good sold raps to the base of the kettle and then some to the base that plugs into wall. Walla! The kettle is now working. I pray it continues. And, from now on I'm unplugging base after each use :)
Jan 15, 2012 | Kitchen Appliances - Others
My daughter bought me an Alessi cordless kettle for Christmas 2008. After 9 months it simply stopped heating water! The red light was lit on the base, so we knew the fuse hadn't gone, but it was completely...
Have you tried using it on a different socket outlet ? Possibly there is a problem with the wiring at this socket.
If the electricity supply "trips" at the consumer unit it is either the RCD which trips due to e.g. the base of the kettle becoming wet or alternatively the MCB tripping due to an overload which shouldn't happen unless there is a fault in the kettle.
When you got a replacement kettle presumably they replaced the base also?
Sep 01, 2010 | Alessi Al384730-640 Cordless Electric...
I have a dualit 72402 kettle which is not heating,when put on base, switch will stay down and neon lights possibly the element has gone but I cannot unscrew base of kettle to check it,do you sell this tool...
I have a similar problem and spoke to Dualit who say that the element is probably blown. As the unit is sealed into the base it is not repairable and should be scrapped. Not really a solution more a way forward
Feb 17, 2010 | Dualit (7202) Cordless Electric Kettle
Plug in, nothing happens...
This usually happens when the overheat-cutout is activated (for example after turning on the kettle with little or no water).
Look on the bottom or sides of the kettle for any 'reset' like switches or buttons. Usually this consists of a 'hole' in which you have to insert a paperclip or pen.
Dec 10, 2009 | Televison & Video
Dishwasher won't start
may be in flood mode. tip the unit sideways and see if water leaks from the base if so continue to tip it until it all drains out, then start it on a wash if it starts you have a component leak that will have to be sourced.
Mar 14, 2009 | Dishwashers
Switches off before full boil
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top KitchenAid Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
