Watches Logo
Paula Crissman Posted on Feb 03, 2017
Instructions for accutime stainless steel mickey mouse mens watch #MK2051
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 17, 2008
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 14, 2009
SOURCE: Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Dennis Fitzsimmons
  • 28 Answers
  • Posted on Jun 15, 2009
SOURCE: no watch setting directions
Some of the inexpensive watches like to mimic the expensive watches and put fake dials on the face of the watch. That way you get a Breitling look alike at the price of a Timex. If there don't appear to be controls for the dials, chances are that they aren't real dials, Look closely.
Anonymous
  • 9 Answers
  • Posted on Jan 01, 2010
SOURCE: how do i set the gmt on my Invicta Men's Pro Diver
Set it only at night but not between 8 and 2. Use the johnson rod that came with it.
Anonymous
  • 302 Answers
  • Posted on Nov 02, 2011
SOURCE: Have an Ebel Men's Watch:
Well, Mr Spencer is partly correct. The second is telling you your battery is about to die. It is called the "eol" or "end of life indicator" Not yours! Your battery. Notice the time is still correct. This is a feature some better watches have to tell you your battery is about to go dead. I am a Wostep graduate and any watchmaker with a Wostep certificate can handle your battery replacement. Mr Spencer is touting the line the manufacturers tout. Your battery exchange shouldn't cost more than 15 dollars. Send it to Cartier and prepare for a shock!
Large Disney Mickey Mouse Watch # MK1130 0613? BATTERY?
The simplest solution to this is to get a watch repairer to do it for you. They usually only charge a small fee to do it and just takes a few minutes.
If you can get the back cover off the watch the battery will have a size code marked on top of it, often an AG- or an SR- number. This will give you the size of battery you need. I think your watch has a 'push fit' back plate.
*Note* If your using something metal as a lever it could scratch the watch.
CAREFULLY using a blunt edged lever GENTLY lever the back plate off. This should reveal the battery. When refitting the back plate it should click into place using a firm, even and gentle pressure.
2answers
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
I have a minnie mouse that was made in 1928! does any one no howmuch itz worth its called classic mickey!! please
mcdevito75 here, hello miss d, the first Mickey watch Disney came out with was in 1933, Mickey was invented in 1928, if this is a picture of your Mickey above, then it wa made in the early 1980"s. If it's working very well it could be worth a collector value of approx. $30.00 --$50.00
6helpful
No watch setting directions
Jun 14, 2009 • Watches
Top Stainless Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Stainless Watch Expert? Answer questions, earn points and help others
