Question about Dual Audio Players & Recorders
I have a Thomas Pacconi Model TPC-MSE-807 turntable. The Power/Volume Control has gone on it.
It's a dual potentiometer with a switch on the end marked A503 .. Does anybody know the rating for the switch ? I can work out the pot ratings
Posted by Jonny Quinn on
Lawrence Oravetz
  • Dual Master
  • 10,548 Answers
Look on the data plate to see if there is a voltage and current draw value on it. The switch should be rated at 120 Vac @ 10 A.
Posted on Feb 02, 2017
Testimonial: "Ok the data plate says : POWER SUPPLY : ~ 230V/50Hz POWER CONSUMPTION : 19W"
I need a needle for thomas pacconi phonograph model tpc-hd-12 can you help?
What you do is look at the cartridge it fits in, then note down the make and model number and enter that into Google. The stylus should then show up.
May 30, 2016 | Audio Players & Recorders
Volume control not working
Left and right wires are like the ends of a carbon resistor.
The centre connection is the slider that slides along the carbon resistance.
Spray inside the device,
The centre sliders often loose connection from overuse.
Carefully take apart and clean & put slight tension back on centre slider.
Look to see if carbon track is worn out?
Take the centre wire off the Pot and try it on either end.
One will be full volume the other will be lowest volume.
Read the Ohms value of the Pot (stamped on)
or use a cheap Ohm section of MultiMeter
Note the size of threaded area
Get similar to take it's place
1M 24mm Potentiometer Linear Single Gang Potentiometers Resistors Passive...
Potentiometer Wikipedia the free encyclopedia
Sep 19, 2015 | Audio Players & Recorders
I have Thomas Pacconi 3-speed phonograph model TPC-7475 and wanted to attach external bookshelf speakers. Is there any way to hook speakers up to the line out jacks?
You need to buy the Jack's male plugs, Wal-Mart has them if memory serves, and splice your speaker wires onto them, preferably with a soldering gun and heat shrink insulation.
Jan 12, 2015 | Seth Thomas Pacconi Turntable
How can i repair my radio that seems to get no power when i turn it on
Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the unit and be able to use a soldering iron. If this isn't you then take it to a repair shop.
Sep 06, 2014 | Audio Players & Recorders
Thomas pacconi # tpc-mse-800-o (no power)why is there no power getting through hole unit?
Since you have no sound even on radio, it's not going to be a bad tt motor. There is no fuse except for a thermal fuse inside power transformer. I would start with a continuity check accross both of the blades on the plug. If it's open, you prob have a bad power transformer.
Sep 06, 2014 | Seth Thomas Pacconi Turntable
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
I nned mxr fullbore pots replacements
Usually with volume pots,the ratings dont matter. you can really buy then anywhere like guitar center,micro center and online. they're really cheap and well worth it.
Oct 04, 2017 | MXR M-116 Fullbore Metal Guitar Effects...
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
