SOURCE: Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
SOURCE: Dishwasher doesnot drain
Once you ensure that the drain lines are clear, this usually means that the drain pump is stuck, clogged or faulty.
Try first unplugging power cord for ten minutes.
If this does not help, the pump is clogged or defective.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
SOURCE: How do I replace the heating element for a Bosch SHU53 dishwasher
are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
SOURCE: Missing instructions Bosch MAXX 4 Comfort
Click on the link below ,fill in the details re the model number and it will be available as a .pdf
http://www.boschappliances.com.au/content.asp?document_id=192
If you have not got Adobe Reader go to www.filehippo.com and get a copy there
SOURCE: My DX302 dishwasher wont heat the water, the
Yes I had the same problem with the DX302. One of the solder joints on the relay was cracked but hardly visable. Resoldered it and no problems.
How to do it:
Make sure you turn off the power at the wall and pull out the plug. To get to the circuit board remove the screws on the inside top of the door and pull out the front panel (where the buttons are). Press the little clips and the white box containing the circuit board comes free. Remove all the plugs and lever open the small clips holding the box shut. After you open the box pull the circuit board up and have a look at the contacts under the black little box (relay). Use a soldering iron and some flux cored solder and redo the joints. Put it all back together and turn on to see how it goes.
Worked for me.
All the best......
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
e
Hi, thank you for answer, there is not a wiring diagram inside the machine, it was only a user manual that was delivered with the machine and not a repair manual. I have opened the dish washer and done some fault finding. Bosch will not send me the wiring diagram, only give me the phone number to their service centers.
