Question about Vacuums
Brush rotates but vaccume does not work - Vacuums
Posted by Geoff Hine on
Sandra Ethier
    New Friend:
    Problem Solver:
  • 19 Answers
The vacuum is what makes the brushes turn. You sacked something big and hard up yhe hose. Clothes pegs are sneaky
Posted on Feb 10, 2017
Should the rotating brush be rotating at all times when vaccuming
The brush should rotate when you are vacuming carpeted floors but not when vacuuming hard surface floors.
Jan 19, 2017 | Dyson Vacuums
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
Brushes wont rotate, no blockage and seal working perfectly. there is no difference when I turn on and off. but the noise when a turn on, for brushes to rotate.is louder. It was just turning slowly and...
I don't know what model you own, but all the models I owned did have a driving belt for the brushes. Usually situated at the bottom and can be accessed by removing the screws from the bottom cover. Hope this helps!
Oct 12, 2013 | Vacuums
My rotating brushes have stopped rotating
Almost certainly you have broken a drive belt. It is not a big deal though just turn it upside down and remove the base plate you should be able to access the belt from there. You should be able to get a belt pretty easy from an online retailer like vacuumspot
May 07, 2012 | VAX Appliances Vacuums
Dyson dc 35 the floor brush wont rotate
My brush on my Dyson DC35 wont spin.
Feb 29, 2012 | Dyson DC35 Handheld Vacuum
It is a dirt devil Royal which I use to vaccum stair steps. it is a new vaccum . not it will not work, the brush will not rotate. I looked to see if some hair was the problem but no hair or fuss. ...
Hi, I am sorry it took this long to get back to you and I promise I will get right on this. We are having issues with our e mail notifications.
You say this is a new vacuum, do you mean brand new? never used before? I am going to look into the dirt devil problems and see if we can narrow down the causes. I assume you tried this in several outlets to make sure it is not the outlet. Does the motor run at all? or is it running but the brush not turning and not picking up dirt.?
Nov 07, 2011 | Vacuums
The brush on my vaccum stopped rotating, we replaced the belt thinking that could be the problem. It seems that the belt is working fine and the brush will not rotate even manually- what can I do to get it...
Remove the brush from the machine and clean as best you can. At each end of the brush there is a plastic clip that holds it into the vacuum. Add some WD40 between the clip and the brush and turn the clip around the brush until it moves freely. Do this for both ends. Reassemble making sure the belt is properly installed.
Oct 13, 2010 | Bissell 6595 Lift Off Bagless Upright...
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
