SOURCE: Epson Stylus C68
Turn the printer off. Open the cover and check for any foreign objects that can cause your print head not to move. Check if you have put the ink cartridges correctly and make sure that the cover for the ink tray is closed. Turn the printer on, if your going to see the same status of the lights, it will be a hardware issue.
Contact Epson Technical Support.
United States
Phone Number: (562)276-7525
Hours: Mon.- Fri. 6AM-8PM (PT)
Sat. 7AM-4PM (PT)
Canada
Phone Number: (905)709-2567
Hours: Mon.- Fri. 6AM-6PM (PT)
SOURCE: epson r800
Here is the problem... Because the printer has more then one feed, your program(i.e. MS word) is selecting the CD tray by default.
The solution in MS Word is to go to the Envelopes and Settings then select OPTIONS.
There should be a option in here to select the other tray.
SOURCE: toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
SOURCE: i have a denon 1720
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
if there is a small hole on the panel of your dvd drive push a staightened paper clip inside until you feel it press down this will open up the drive
hope this helps
