Question about Konica Minolta Office Equipment & Supplies
How to reset drum counter or at least keep printer running after drum end of life?..printer is konica minolta bizhub c554e
Posted by ayman awwad on
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,958 Answers
Replace the drum unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 11, 2017
5 Related Answers
Geoff
  • 562 Answers
SOURCE: How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
Posted on May 07, 2009
steve p
  • 44 Answers
SOURCE: How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
Posted on Nov 29, 2009
Anonymous
SOURCE: Can I reset the drum counter for a Konica Minolta
The best way to reset the counter is to replace the fuse on the underside of the printer drum. That is not hard to do, but you have to be careful not to break the plastic tabs holding the original fuse in place.
Posted on Mar 29, 2010
xeerie
Zaheer Ahmed
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
Please show me how to reset drum error for Konica-minolta bizhub 20
Bizhub 20 drum reset Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately. Make sure that the machine is turned on. Press Clear or Clear/Back on the control panel
Apr 19, 2018 | Office Equipment & Supplies
Installed new drums in konica minolta bizhubpress c6000 drum counter did not reset automatically. How do I reset them?
service mode then clear the counters, should have done it before installing the drums.
Oct 25, 2016 | Konica Minolta Bizhub Press C6000 Copier
BIZHUB 164 error M2 what have I to do
replace the drum and developer and then reset the counter
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
Drum konica minolta 250
Bizhub 250
The drum part number is 4068612. You need to replace developer at the same time, 8938451. You also need to go into service mode and reset the counters and run an f8 after parts are replaced.
Jan 28, 2014 | Konica Minolta bizhub Office Equipment &...
Getting c2557 code how do I fix? on bizhub 350
Welcome to Fixya
Sounds like you nee to replace the developer. Try to reset the printer first. Enter the service menu by pressing utility > original size> stop>0>0>stop>0>1 the password is 00000000, in the service menu select tech mode, go to counter and clear the life of the developer and drums and then run F8 from functions.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jul 02, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
NEED TO RESET THE DRUM LIFE AND STARTER . NEED THE PROCEDURE TO RESET THESE WARNINGS
Unfortunately The minds at Konica Minolta have figured out how to make the machine Inoperable if you reset the drum and or developer counters, the only way to reset the "change drum" condition on a Biz 350 is to replace the drum AND the developer and calibrate them both when you do it automatically resets the counters... sorry.
Sep 29, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
In minolta bizhub 350 pc drum change
Two Options:
1) Reset the PC/life; I/C Life and DV counter and run F8.
2) The same than before but change the PC drum.
by : George Rivas ( OSI )
Feb 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
'DRUM CARTRIDGE END OF LIFE' MESSAGE
The back right of the drum has a small 20mm F80mA fuse that you need to replace to reset the drum counter.
(fuse blows to reset the drum life setting)
May 09, 2008 | Konica Minolta magicolor 2430 DL Laser...
298 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
