Microwave Ovens Logo
Question about Electrolux Microwave Ovens
Hi, we have an electrolux builtin microwave.when on standby it occasionally makes a crackling noise not unlike a laptop or storage device when it looks for data. Microwave runs fine otherwise
Posted by Steven Loones on
William Miller
  • Electrolux Master
  • 9,179 Answers
You really need to be sure it's not running by itself - even intermittently - because that can cause arcing damage, or even a fire.
If you're not sure, leave the door open or the oven unplugged until you're sure it's not or it's fixed.
You can keep a cup of water in it and check it hourly over the course of a day to see if it coming on and actually heating.
It really shouldn't make any noise when idle except a gentle 60Hz hum.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information.
* on the tag in cooking cavity or around door frame or control frame or on back
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Posted on Feb 05, 2017
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
Posted on May 01, 2007
Anonymous
  • 173 Answers
SOURCE: Buzzing Microwave
the buzzing is the magnatron tube juicing too thousands of volts before emmitting the micro-wave radiation to what your cooking that turns molecules 180 degrees around... guess that friction is what really heats it.
radar ovens is what they use to call em and even people would stand in front of big ones to warm up long ago...lol canibles will love that.
Posted on Jan 19, 2008
Anonymous
  • 112 Answers
SOURCE: Kitchenaid builtin microwave buzzing
I would recommend changing the diodes as well. This will usually take care of the problem.
Posted on Oct 25, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Crackling sound in microwave vent when power is off
By "powered off" can I assume you mean that it is plugged in and at idle, not cooking, just showing the clock?
If so, I'd say your control board is failing.
If my assumption is wrong, please write back with more details.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Posted on Nov 09, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 01, 2009
2answers
Is it normal for a microwave to make crackling noises when standing and not in use but plugged in ?
A microwave in standby mode should not crackle. There might be a slight humming sound from a transformer, but that should be all the noise it makes. You could have a transformer or control panel component that is failing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
1helpful
My kitchen aid microwave makes a loud crackling noise every once in awhild
Is it a carousel (turning platter)? if it is, than it is probably dirt on the platter support wheels and the platter support groove/track on the bottom of the oven, clean the glass plate, the support wheels, and the bottom groove as well, if you want to make sure the crackling comes from the carousel system, take it all out (support and platter) than place a glass of water in the oven and start it, if there are no crackling noise than my theory is correct, if the noise is still there than have it checked by a professional technician...
1helpful
Rattling, crackling type noise just started and is constant when microwave is running.
A couple of months ago my microwave started making crackling, rattling and grinding sounds everytime i used it and i thought it was going to break down. It turned out one of my children must have spillled or overflowed something with a clear liquid because the micro did not look dirty but there was a crunchy substance under the wheels of the turntable. Once i cleaned this up totally the noises all went away.
1helpful
2answers
My microwave is making a cracking sound like if it had metal in it but i took everything out and its still making the cracking sound. What could be causing this sounds if microwave is empty?
A contaminated wave guide cover will crackle and spark.
They should be periodically checked, cleaned or replaced.
Contact Maytag for replacement parts.
Hope this fixes your noise.
1helpful
Turned microwave on this morning ,sudden crackle,then nothing.
Sounds like something has shorted out-blown. Unless it is a very expensive model it won't be worth fixing and is not something you should attempt yourself anyway. If under guarantee then get it repaired via the guarantee arrangements. No harm in checking the plug is wired properly but as the light and timer are working it is very doubtful it is a connection problem. I think you need to buy a new microwave!
William E. Miller
[email protected]
3helpful
Top Electrolux Microwave Ovens Experts
Paul Bade
David Shaub
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
