Question about Alba Televison & Video
Hi Alba 19" tele, how do i turn narrator off please
Posted by Paula kelshaw on
Alba LcD32880HDF. How do I reinstall free view channels.
Try here;
https://manuall.co.uk/alba-lcd19880hdf-lcd-television/
Page 19 is the stuff you'll need.
You will need an aerial plugged into the TV to receive the DTV signal in the first place.
Best of look.
Mar 09, 2018 | Alba Televison & Video
Turn off narrator
Hi
Go to control panel.
Select ease of access center.
In the options mentioned select "use the computer without display"
Uncheck "turn on narrator."
And apply the settings.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 07, 2014 | Dell Computers & Internet
Alba 19 inch lcd user manual
I found the manual for the Alba LCD19880HDF here: http://www.tvrepairman.co.uk/manuals/alba/MB45-RC1205.pdf .
I hope this helps.
Jul 17, 2012 | Sharp 19 in. LCD HDTV
How do I turn off VERBAL narrative on my Alba TV
If you have your remote, look for the close-caption button or symbol...By pressing that you should be able to turn it off....
Sep 19, 2011 | Televison & Video
Not sure if anyone has come across this problem before. I have had 3 tv's in my son's room and all 3 different models including old one alba 19 inch lcd and another all just stopped working....
jotvguy just wondering, is there definitely power in these outlets ? Have you tried a lamp or something else to prove you have power at the wall outlet?
Jul 11, 2011 | Televison & Video
Hi. I have an ALBA LCD32880HDF television which I purchased in August 2009 so just outside warrenty. I have been on holiday for a week and had switched the television off at the wall and returned home...
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
Oct 24, 2010 | Televison & Video
I bought an Alba CDVB4 and the remote isn't right
Hi
Not sure if you found the problem for this, but I had the same problem and couldn't find any reference to this except your question so thought I would put up an answer in case it can help you or anyone else.
Aparently, Alba have got hold of the codes that Toshiba use for their remote controls, so if you have a Toshiba telly an Alba product like this won't work. The only solution being to return it and get a different make.
I returned mine twice for a straight exchange thinking it was just a manufacture fault before I found this out. I then exchanged it for a Bush set top box - only a fiver more - and it now works PERFECT!
I hope this helps some.
Zoe
Dec 04, 2009 | Televison & Video
How to take narrations off of power point presentations
Turn narration on or off in a presentation Turn narration on or off in a presentation
  1. On the Slide Show menu, click Set Up Show.
  2. To turn narration on or off, clear or select the Show without narration check box.
Please don't forget to rate me..:-) Thanks..
Nov 08, 2009 | Computers & Internet
Televison & Video Logo
29 people viewed this question
Top Alba Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
