Question about Johnson Boating
What is the plate behind the carby with fin like things on Johnson 6hp
Posted by Michelle Williams on
Jeff Gorham
    Loyalty:
    Visited the website for 30 consecutive days.
  • 180 Answers
Sounds like your describing the reed valves. They open on the intake stroke to let the air/fuel mixture into the cylinders.
Posted on Feb 04, 2017
1973 Johnson 65 hp outboard. It runs smooth, but won't accelerate at full throttle.
have the carby professionally overhauled
replace all rubber hoses from the tank , including having the fuel pump overhauled
the rubber parts break down and deposit small bits rubber in all of the jets in the carby
Jul 20, 2017 | Johnson Boating
How do you turn a 6hp boat motor to a 8hp motor on a Johnson 1993
cheapest way is to buy a bigger power head
you may achieve the desired power by boring and fitting bigger pistons but you will have to have a long talk with a dealer service center technician to see if that would be feasible to do
as the motor is quite long in the tooth, it may be a better to consider a late model or new unit as the advantages of the later technology will be beneficial in the long run
Feb 01, 2017 | Johnson Boating
I have a short shaft Johnson 6hp outboard, the Jon boat I mounted it on is too deep, and motor doesn't reach water. Is there a way to lower motor? A bracket to lower motor to reach water?
outboard motor manufacturers supply a long shaft leg for just this problem
Talk with your Johnson dealer and check used outboards on e bay
Lowering the whole motor may affect the boat and floatation aspects besides making it harder to steer and start
Apr 15, 2015 | Boating
Johnson 6hp outboard engine fuel pump diagram
Here is where you can get a service manual, they have a lot of info you might need...
Johnson Evinrude Manuals 1917 2007
Jun 11, 2012 | Johnson Boating
6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Sep 16, 2009 | Boating
Tryng to drop gear box off 6hp johnson how to?
If you are talkinh about unhooking the shifting rod from the lower unit, it might be behind a small plat held on with 2 screws on the side of the motor towards the bottom (casing that the lower unit dropped out of) or look uo in the housing , you should see how it is connected, usually a small bolt
Apr 24, 2009 | Boating
Manual for a craftsman 6hp shredder
Go to Sears Parts Direct and put your model number in and a parts list will come up. You can order a part or even a manual. I think this will help you. Don
Mar 17, 2009 | Heavy Machinery
Boating Logo
1,350 people viewed this question
Top Johnson Boating Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
