There should be an adjusting screw around the bar somewhere. Turn it anti clockwise until it stops and then just crack it one turn. If it still leaks too much then turn it down slightly.also try and store the saw on its side to stop the oil just coming out.
Hi, What Kind of oil do You use? A thiker one could be a solution.
Usualy there a other screw (than those H and L of the carburator) to adjuste the amount of oil spend on your blade.
There is no adjuster for the Husqvarna 450. Husqvarna recommend that if there's not enough oil reaching the bar that you slow down the engine by adjusting the carburettor screw. I have the same saw and also wanted to adjust the oil flow. I didn't change the carburettor and it's still cutting away without doing any damage. It's meant to use less than a tank full of oil to the tank full of fuel when you're cutting near constantly. With stops in between it will use more fuel and less oil.
Remove the bar and chain. Clean the engine side case where the bar fits. Does the oil port itself leak or is it coming from the engine case? If from the case, it may be a loose or split line from the tank or it could be a cracked oil tank. If the tank is cracked, replace it as there is no glue or epoxy that can permanently repair it. If the leakage seems to have stopped, clean the drive end of the bar including the two small oil passages that run out to the chain groove. Re-assemble the bar and chain, then run the bar tip at speed near some cardboard for a few moments--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw located near the chain return area on the back or underneath the case. Adjust CW to reduce the oil volume. Hope some of this helps!
Most chainsaws have an adjustment for bar oiling and its quite normal for a chainsaw that is stored for long periods of time (weeks or even days) to leak out the bar oil. This is normal for chainsaws stored for several weeks or more.
Some of it may be reduced by adjusting the rate of flow for the bar oiler, read your manual carefully before attempting to adjust it. Adjust to too slow a flow rate will have adverse effects on performance and can lead to premature chain or bar failure.
Recommend that if you are going to store your chainsaw for more than a couple of weeks, drain the bar oil back out if it into a container (strain it through a paper towel before returning to your bar oil can). Also, you really should drain almost all the fuel and then run it until it shuts off if you are storing it for a month or more.
Hello there. Regarding the bar oil, many loggers plan their work so that they are out of bar oil at the same time that they quit for the day because bar oil has a tendency to leak. Another method that has some success is to mix your bar oil with a heavier oil but the trade off might be less lube getting to the chain when you need it.
Regarding the chain moving in idle, this is another common problem. You can usually slow the idle down until the chain stops, as you indicated, but I too have had chain saws where I finally just decided to live with it and be extra attentive to what was going on.
You can try to retorque the pan bolts and this may slow or fix the leak. This is probably the easiest thing to try.
You may be able to drop the pan down to the cross member and sneak the gasket into place. This is more difficult, but may save having to jack up the engine.
You can't remove structural bar.
If you do decide to lift the engine, you can probably replace the gasket by lifting the engine while everything is still connected.
Good Luck with your project.
Tim
Thanks Ford! You could have made a bolt on crossmember.
