Question about OKI Office Equipment & Supplies
I am geting "Service call required" error in my OKI C831 printer. May you please advice me for farther action to solve this issue?"
Printer rebooted. Printer Online. Factory resset can't be done as power button is not responding. Toner, paper is ok(I would say I didn't check if there is a paper jam or issue with the fuser).
Posted by Lyes on
5 Related Answers
blady007
SOURCE: canon iP 3300 printer service error 6502
CANON PIXMA IX IP 4000 - error 5100 and error 6502
While testing the printer the cover must be closed!
So if you have a CISS in your printer you have to close the cover after replacinq cartridge because after that
replacinq the printer is testinq the cartridges also with the blinkinq LEDS which are installed on the ink's!
There is a light LED sensor under the cover which detects the blinking.
So if you have destroyed the LED on chips or if you covered them with glue OR if you will leave the cover opened
and press cover-open detection button with a pen (then the day ambient light will come inside to cover)
you will get an error 6502 or error 5100. I think that the same error will come with all printers which use
CLI8 CLI-8 cartridges.
Remebre that the blinking led have to be clean and blink after installing new cartidge.
Other reason is that you mixed the chips ang give i.e. chip from yellow to blue and blue to i.e.red. and black to yello etc etc. (YOU MIXED THEM :) )
I hope it will help
Posted on Jun 16, 2008
parkerguy
  • 138 Answers
SOURCE: HP 2820 printer 50.2 fuser Error
Your problem is in the fuser. 50.2 means the fuser is not reaching temerature properly in the allotted time. It either has a burned out ceramic heating element or thermistor (hi/low thermometer).
Here's a link to a free service manual that will walk you through testing it.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%202820,%202830,%202840%20Parts,%20Service%20Manual.pdf
Hope that helps you. If so hit it with a FIXYA rating. :o)
Posted on Oct 19, 2008
Anonymous
  • 22 Answers
SOURCE: How to solve "reboot printer
This is a fuser disconnection error. Try to remove the fuser and put it back securing properly in its place.
Posted on Sep 24, 2009
Anonymous
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
Anonymous
SOURCE: My oki printer b430dn is flashing 380 paper jam
Hi
You have to look under the cover remove the black plastic cover, Remove in the left side by sliding the litte plastic tab in to the mittele and gently pull up, when it is loose in the left side slide it on to the mittle and it will go of in the right side too, Now remove the next black plastic cover, it's all black with at little "sharkfin" i the center, Just pull genltly upwards, and under there is the "380" It is at little tab, just wrikele it a few times. Now just assemble the printer an you are good to go
Posted on May 17, 2010
I'm getting a service error 02 in a printer oki b6100. How do I solve this problem?
The OKI B6100n Laser printer is a unique printer. These Error messages are to enable you detect the fault and resolve it if you can and the once you cant it resolve,u call the repairman.
The Service Error 02 means that there is a paper jam inside the printer and the only way to resolve it is to remove the paper from the indicated location on the printer.
You can also check the user manual on the CD ROM of the printer for more information and how to correct similar error messages on the printer.
Thank you.
Sep 12, 2011 | OKI B6100n Laser Printer
Fatal Error 121
Hi and welcome to Fixya!
"Fatal Error" on your printer display or status monitor simply means a problem has occurred requiring action to clear. Fatal Error explanations are not usually found in the manual. You can check the list of error codes from the link below:
http://www.c8600.co.uk/index.asp?printername=C8600&menumode=0&content=errorcodes
RECOMMENDED STEPS:
First, try turning off your printer then turning it back on. If you're still getting the same error message, make sure the printer is plugged directly into the wall. Often, the issue is power-related.
If the problem persists, write down the message including the 3-digit error code number and send an email to "[email protected]" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers scrolling across the display after the 3-digit error code, write it down and report them when calling or emailing Customer Support.
Jun 29, 2011 | OKI C5800Ldn Led Printer
ERROR 173 050914
Low fuser Temperature Error - Replace fuser or thermistor in the fuser - per Oki Svc Mnl
Fuser error. Replace fuser or if no-go, Main board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 27, 2011 | OKI B4600 Printer
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "[email protected]" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 25, 2011 | OKI C5200n Laser Printer
Fatal error 708
Dec 14, 2010 | OKI C3530N Color MFP Printer
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
May 08, 2010 | OKI C9600hdn Laser Printer
I GET ERROR CODE 010-349 WHEN TURN PRINTER ON
Hi!
The error issue your printer is facing means "Fuser STS Front Disconnection fail"
First try to reset the printer by powering off and then on. If the problem still persists then you need to detect fuser or fuser assembly which is required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 25, 2009 | OKI B6300 Laser Printer
OKI Pacemark 4410 Problem
Unit requires service, this is a valid error. Blown fuse on PMA PCB.
Feb 07, 2008 | OKI Pacemark 4410 Matrix Printer
OKI B8300 Call for Service error
http://www.printcopy.info/shop_e/cdrom.php?brand=OKI
Here is a link to service manuals for OKI
Feb 07, 2008 | OKI B8300 Laser Printer
OKI C7300 Printer
moz-screenshot-1.jpg Unfortunately it's a Hardware problem.
If you bought it from a dealer, contact them.
Error 020
When an error has occurred in the controller board (CU) or the program Rom.
Resolution:
Replace the Rom Dimm, see chart below for the correct part number. If the Rom Dimm does not correct the issue, then replace the (CU) controller board. Please refer to the service manual for (CU) part number depending on the printer revision
Dec 01, 2007 | OKI C5300n Led Printer
425 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
