Question about Measuring Tools & Sensors
Why is my outside temp not registering. I have replaced the batteries
Posted by karen morgan on
Bought inside/outside wireless weather station. Inserted batteries as directed. Inside works, outside temps don't register at all.
Make sure that the channel (1,2,3) agrees between the sender and base. You might try a different channel due to interference. double check batteries. Then -- remove batteries from remote and base. Then put batteries in remote first (should be next to base) then insert batteries in the base. Be sure channel is in agreement between the units. Sync can take a minute or longer.
Apr 16, 2018 | Measuring Tools & Sensors
How do I program Taylor in/out thermometer-clock and get outside temp to register? How do I program the clock?
Hit reset next to batteries to have it sync with outside temp sensor. Push mode button to scroll thru date, time. Use up and down button on back to adjust numbers.
Mar 03, 2015 | Taylor Measuring Tools & Sensors
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Nov 07, 2014 | Sharp Atomic Dual Alarm Clock Spc315...
I followed the instructions to replace the AAA batteries, but the outside temp won't properly register.
I think yolu answered your own queistion there. Its gone faulty, probably in the logic chip. These things blow so easily and are made so cheaply- even the best of them- that when you return them under warranty they toss them in the garbage or recycling and hand you a new one. Its not repairable. Take it back or send it back. Demand a new one. A reputable dealer or company will not argue.
Mar 18, 2013 | iPhone Apps
We replaced the batteries on our SIO SCAN temp transmitter but it still will not register the outside temperature--what do I do?
Take the batteries out of the clock AND the temp transmitter. Wait about a minute, then replace the clock batteries. Wait another minute, then replace the transmitter batteries. Once the clock synchronizes with the satellite, you will need to set the time zone and whether you want DST on or off.
Dec 08, 2009 | SkyScan 86709 Atomic Wall Clock
My clock will not display the outside temp. after battery replace
Try replacing the AA batteries in the main clock/display unit - that worked for me, then you'll probably need to press the reset button next to the AA batteries, and maybe the reset button next to the AAA batteries in the remote unit - press reset on the main unit first. My remote is now registering and the red light is flashing, but I don't know how to reset to the correct time and date - it's been scanning for a while and found nothing...
Nov 21, 2008 | Audio Players & Recorders
Measuring Tools & Sensors Logo
1,295 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
