Question about Miele Cooktops
SOURCE: 1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
Posted on Sep 13, 2007
SOURCE: Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Posted on Jun 18, 2009
SOURCE: Miele KM 342 - I have burner - will ignite when
Hi dear.According to you're explanation,there is flame failure safety device in each hob.Please check the hob,there is one ignition plug & one prob next to each other.Please clean them up with hard brush to get rid of the cleaning chemicals(Like: CIF)residue.It's a sensitive prob becareful when you do this.Please make sure it sees the flame.As long as it feels the heat it'll let hob to run.If that's not work,you may need to change it.Please do this if you know what you're doing,other wise call service department.I hope that helps.Thanks.
Posted on Sep 02, 2010
SOURCE: I have a Miele KM424 electric cooktop and one of the elements will not turn off?
may be one of the circut boards
Posted on Mar 24, 2013
