Question about Whirlpool Dryers
My whirlpool cabrio Dryer wont start, drum light inop as well Dryer was working then would stop mid cycle. I unplugged dryer to reset and plugged back in. Now no power
Posted by Jeff on
Whirlpool
  • Official Brand Answer
  • 408 Answers
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at [email protected] with your name, address, phone number and the model & serial numbers of the Washer.
Posted on Jun 20, 2017
5 Related Answers
Anonymous
SOURCE: Whirlpool Dryer LER7646EQO - Won't Start
my whirlpool electric dryer not turning,there anyone can help
Posted on Mar 27, 2009
Anonymous
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
Anonymous
  • 81 Answers
SOURCE: admiral capacity plus stopped working mid cycle no power
When u press the knob to start the dryer is there a buzzing noise ???
If so i guess u nee to order a new moter ...
u can do it at..www.appliancepartspros.com
Posted on Jan 07, 2010
jumptrout51
steve
  • 3361 Answers
SOURCE: Control Panel in my whirlpool duet dryer model
First check for 220 volts incoming power to the dryer at the terminal block on the rear of the dryer.
If you have 220 volts,check continuity on part number 59(thermal fuse) in the attached diagram. No continuity is a bad part.
cut and paste this link to your dryer diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139909&diagram_id=951915#d951915
Posted on Jul 24, 2010
Tim Whalen
  • 3074 Answers
SOURCE: My whirlpool cabrio front load dryer will power on
underneath the lint trap is a sensor, it will need to be cleaned. Good luck Tim
Posted on Feb 20, 2011
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at [email protected] with your name, address, phone number and the model & serial numbers of the Dryer.
Jan 28, 2017 | Whirlpool Dryers
Whirlpool Cabrio Dryer Wont go past sensing light when I press start. The door is tightly closed and the filter is clean. It just won't even try to start it just just beeps once.
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
Nov 04, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Cabrio Dryer runs for 5-10 Seconds and then the drum stops.
Go to: RepairClinic.com
to troubleshoot your appliance.
You'll need the make & model #.
Nov 16, 2008 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio Electric Dryer - No Power
you have to send the model number off of the dryer,also if the dryer hasn't been taken apart and cleaned out also the vent line it could be clogged with lint and you could have popped the thermal fuse or something like that,you'll need a meter,unplug it take it apart and check the t-stats to see if one of them popped,or if it has a belt switch the belt could have broke but if you want to fix it send the model number and more info like any lights coming on but it won't start?if so then you know power is coming to the dryer but it won't start stuff like that.
Dec 26, 2017 | Dryers
Dryers Logo
129 people viewed this question
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
jdthefixer
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
