Question about Invacare Supply Group Health & Beauty
SOURCE: Brake clicking
hiya may i suggest you inspect the front brakes pads and discs for wear and discs for damage /scoures considering age of vehicle? when was last service inspection on brakes etc? if you do not feel competant to check brakes ? quite understand you could pop along to nearest national tyres depot and ask them to check brakes as above and also driveshaft cv joints for wear as these cv joints also give clicking sound when driving tyre dpot do not usually charge to check but will try to obtain job and give you a quote! if you have diagnosis and £££££?quote ? by all means come back with update and glad to offer help and advice if you wish ? hope this helps you as to probable cause? either way repair/s will not be too expensive best wishes
Posted on Oct 24, 2008
SOURCE: when driving getting a loud clicking noise coming
sounds like you got a worn outer cv joint, check and replace
Posted on Oct 30, 2009
SOURCE: My power steering goes and comes, loud squeeling
this peice belongs to your power steering pulley its a plastic o\piece that over time brakes off you can either call your dealer and see if its covered by your warranty because its has to be replaced the pats that the plastic belongs on is top pulley you 'll notice powersteering wheel hard to steer and squeeling you must replace part or adjust it so its holding pulley tight itshas grooves in it 2 as a matter of fact if you keep using this pulley with broken plastic it could brake your belt
Posted on Jan 29, 2010
Testimonial: "Thank you, this is exactly what happened. Shame on Suzuki for using plastic, they now use metal. Have replaced tensioner and all is well. Thanks!!!!"
Posted on Feb 05, 2015
Apr 23, 2013 | Cars & Trucks
Apr 02, 2013 | Nissan Sunny Cars & Trucks
Jan 20, 2013 | 1996 Jeep Cherokee Sport
May 17, 2017 | 2004 Pontiac Sunfire
Jan 30, 2010 | Ford Mustang Cars & Trucks
Dec 05, 2009 | Heating & Cooling
Nov 19, 2009 | Invacare Supply Group Invacare Scooter...
May 28, 2008 | Audio Players & Recorders
Feb 28, 2016 | Invacare Supply Group Pronto M61 Standard...
Jul 15, 2013 | Invacare Supply Group Invacare Pronto M51...
44 people viewed this question
