SOURCE: how to install prince of persia
just insert ur dvd into dvd rom and if autoplay enable then a window will pop up then choose install..
IF not then open MY COMPUTER and right click on ur dvd drive and choose EXPLORE and then double click on SETUP file to start installation..
SOURCE: I WILL INSTALLED PRINCE OF PERSIA THE SANDS OF
YOU HAVE TO PUT THE CRACK IN THE GAME DIRECTORY ''THE CRACK'S ICON LOOKS LIKE THE GAME"
GOOD LUCK
SOURCE: i installed prince of persia
This is mostly caused by an error occurring when you installed the game. I would suggest uninstalling the game, cleaning your registry with a program called "CCleaner" and then reinstalling the game. (Pro Tip: Buy games, don't pirate them.)
SOURCE: princes of persia Warrior within
Have you tried changing the properties of the shortcut to run in WinXP SP2 compatibility mode?
Right click the shortcut, goto properties/compatibility tab, choose "WinXP SP2 compatibility mode" in the dropdown box, then click apply.
This should solve your problem. If not, come back with a bit more detail, and it can go forward from there.
Hope that helps.
Cheers from NZ
