I have a phillips combo tv/vcr working perfectly but when I insert a vhs tape it rejects and switches off. I have tried many tapes all working in my other vcr.the tv is working ok.
Model Phillips pv135/07
Posted by Edmund O Kelly on
  • Televison & ... Master
  • 18,397 Answers
VCR ?? With the possible age of the device, there could be a lot of issues with grease that is old, belts that are stretched etc. A VCR senses tape tension in order to prevent eating the tape. Clean the unit and check all the belts.
Posted on Jan 28, 2017
Testimonial: "very fast response will try advice thanks ed"
Samsung DVD-V3650 Combo Player ejects most videotapes without playing them
You can only compensate for minor scratches. As for the vcr side the rollers could be dirty or the brake worn out. The tensioner may be too sensitive as well. Basically the mechanism probably needs servicing.
Sep 06, 2016 | Samsung DVD-V3650 DVD Player/VCR
Stuck VHS Tape in Samsung TV/VCR Combo
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
VHS tape not working in Samsung TV/VHS Combo and unable to get the tape out
Must take VCR out to remove tape gently.Cause of problem is usually a dirty mode switch.
Feb 26, 2015 | Samsung CXJ1352 13 in. TV/VCR Combo
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
EWC1304 VHS tape shuts off entire system
You probably have a bad or dirty mode select switch. Another possibility would be a gear out of time if a tape was forced in too quickly.
Mar 12, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
