Question about Sony Radio Communications
If anyone of you guys can answer why i cannot fully charge my sony xrs-x3 bluetooth speaker . using a replacement charger?
Posted by Clarence Ebo on
5 Related Answers
vista90
SOURCE: Cobra radar detector speaker replacement
I called cobra support(777-889-3087) and it was around $6 plus shipping for a replacement speaker.
the correct phone number for cobra support is 773-889-3087 and can be found on their website.
Cobra was very courtious and I also got my replacement speaker for my XRS-9500.!
Posted on Nov 13, 2008
Anonymous
  • 134 Answers
SOURCE: ''I have a xrs 9730 radar detector and the speaker quit working''
Most likely the speaker simply blew due to excessive heat. This is a fairly common problem with all makes and models of radar detectors. Contact Cobra. They should either be able to send you a replacement speaker which you can install yourself, or they should issue you a RMA so that you can send in your Cobra for service.
Posted on Apr 25, 2009
partyd
Ernesto Ruesta
  • 141 Answers
SOURCE: TMR-BT8iP not working
this was made to work with any older genegarion ipod that works on firewire power not usb
most ipods
this is not fully compatible with the new iPhone,iTouch new nano and the ipod classic
Posted on Apr 01, 2010
Anonymous
  • 178 Answers
SOURCE: Battery not charging ?
Advise you to buy a new Digital Camera Batteries for Canon PowerShot SD1100 IS
Replacement for: CANON NB-4L
,cheap and good performance.
Posted on May 12, 2010
emissionwiz
Marvin
  • 85239 Answers
SOURCE: can the battery be replaced in my#x3-09 Nextar GPS
Actually, it's quite easy to replace:
Take off four screws at the back.
. Between the body and the front bezel, insert a utility knife. The bezel is fixed to the body with tabs. I started from the left hand side from front. The tab is in the center. Careful not to scratch the bezel or the body. Once one tab is open, you can slide the knife or whatever tool you're using to open the rest. Be careful not to scratch.
Once the front bezel comes off, you'll see that the touchscreen is held to the bezel with the help of four tabs. take the touchscreen off.
Next, take the ribbon cable off from behind the screen. You'll have to flip the flap holding the cable open.
The screen is held to the main board with the help of a tape. Don't take it off. Take off three smaller screws which fasten the circuit board to the back body.
Take the antenna off. It's quite easy. It's the same connector that is used for Blue-tooth or wireless antenna on laptops. It'll just flip off.
vii. Next, take the board off from the back plastic body. The circuit board will still be held to the back by two connectors, one (two wire, smaller one) connecting the circuit board to the speaker, and another (larger one, four wires) connecting it to the battery. Both the battery and the speaker are for now fixed to the back plastic body.
viii. Once you've done that, the battery is exposed. Take the battery off (held by two tapes, and some double sided sticky tape to the back body).
The battery is 35mmx55mmx5mm. Buy any 3.7v battery from ebay. That'll cost you about $10, including shipping. The only problem is that on ebay, you might not be able to buy the same connector. Most of the batteries that you get from there also have protection circuitry to protect against overcharging etc. So you'll only have to replace the connectory. For this, take apart the battery from top. Just peel off the green tape. That will expost the connections. Solder them off, and replace the entire chord on the new battery.
Posted on Sep 13, 2012
JBL Charge 2 stopped wifi connecting to pc
Problem connecting Windows 8.1 pc to JBL Charge bluetooth speaker ...
answers.microsoft.com/.../windows/.../windows8...connecting-windows...
When I try to connect the pc through Bluetooth to the above wireless speaker ... 2) What is the model of the JBL Charge Bluetooth speaker? ..... I am already able to play music from my iPhone 5 on this speaker via Bluetooth with no problems.
Cannot connect JBL Charge Bluetooth - Networking, Internet ...
en.community.dell.com/support.../network...wireless/f/.../t/19525571
Dell
Sep 22, 2013 - 16 posts - ‎11 authors
23 Replies; 16 Subscribers; Postedover 2 years ago ... I'm trying to connect my JBL Charge Speaker bluetooth with my Dell Studio 15 laptop to listen .... I am having the same problem, did you find a fix for this? ... not support audio output, then you need to add a Bluetooth adapter which includes a CD driver.
JBL Charge 2 ' Portable Bluetooth Speaker with USB Charger
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.3 - ‎110 reviews
Most popular JBL Charge 2 wireless portable speaker can charge any devices via USB... You can easily connect Charge 2 to any Bluetooth-enabled device by giving the portable's ..... Charge with proper charger or a USB port form computer.
1helpful
2answers
Unable to turn on my plantronics 210 explorer bluetooth .therefore no light is showing in it. charger is fully charged
Nokia x3 battery not fully charge solution
Try taking the battery out for 2 minutes or so... Place back in the phone and charge while the phone is off.. Give about an hour! If you still doesn't charge you might want to see if the charger has a short or if you need to replace the battery.. Hope this helps!:)
Jul 23, 2012 • Cell Phones
Hai,im using nokia x3.if im charging it, it doesnot get full and it always saying *BATTRY LOW*.If im using this phone i have to charg it while im using it and this thing is stressing because if im going...
HERE'S THE ANSWER TO YOUR PROBLEM:
I believe that the main culprit is your battery itself - its capacity to hold and supply power to your cellphone. These are some of the causes why cellphone battery life are shortened:
1. Bluetooth - it quickly drains battery life
2. Programs running in the background
3. Wi-fi and Data Connections
4. Backlit Screens
Nokia x3 batteries have only 11 hours life when used for calls. So, if in case your battery does not work well, do not think twice to buy a new one. Your battery might have been used up or burn out. Do waste your time bringing charger and charging it always whenever you have calls. Try to think.
I love answering your question. Thanks...
I have a nokia x3 slide.. im having toruble using the headset bec its not going to the headset when im trying to use it,, its always on loud speaker whne i want to listen to mp3's.. also same with the usb...
clean the headset interface jack, and make sure the headset is not faulty. otherwise, try in a another headset. is same, have your phone checked since that could be a problem with phone.
2helpful
2answers
My phones (philips cd445) will not hold a charge for more than a few hours off the cradle...yes I have replaced the batteries, twice. once with disposables, once with rechargeables
You might have what is called "memory'. If you continue to replace the phone on it's charger after each call the battery will "think" it's empty, giving you s short charge time. Next time you replace the batteries (rechargeable) FULLY charge them then leave the phone off the charger until you go to bed at night.
most ipods
2helpful
2answers
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
2answers
Bluetooth doesn't fully charge?
simply check and if possible change the charger.
if the same problem persist try charging with a USB cord(which you have to connect to a PC)
please let me know of the outcome.
1helpful
Everyone else can hear me, but I can't hear them...?
How long have you charged it? Often when you just get them they do not have a full charge and may take a number of hours to charge properly. Try charging it overnight and checking again in the morning. If you are still having problems it must be the device and a return would be in order.
Radio Communications Logo
Top Sony Radio Communications Experts
 Grubhead
Grubhead
durantheman
Dennis
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
