Question about Samsung SYNC SGH-A707 Cellular Phone
Red Battery cover for my samsung Sync
Know where I can get one
Posted by tobykeithfan on
Anonymous
  • 3 Answers
Yeah! google it..... Red battery cover for samsung sync! .... Bam! enjoy >;)
Posted on Mar 21, 2008
What should i do my rock candy wii controller blinks non stop this is the second rock candy controller i brought that will not sync to my wii what should i do ?
Have you tried the red buttons on the wii and controller? The red wii sync button is in the door by the sd card slot and the red sync button for the controller is behind the battery cover above the battery's. Push the red sync button on the wii and then the controller. That should sync them.
Jun 18, 2014 | PDP Rock Candy Wii Gesture Controller...
My remotes were synced to another wii how do I re-sync them?
Step by step instructions on how to sync the Wii Remote or Wii Remote Plus to the Wii console using Standard Mode.
Note:
Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
What to Do:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. If you are using a Wii mini, the sync button is located left hand side next to the battery compartment. The sync button is a darker shade of red than the console.
  3. Remove the battery cover on the back of the Wii Remote to be synced.
    • Some models of the Wii Remote include a hole in the battery cover and a tool on the wrist strap to push the SYNC Button with. With this model, the battery cover does not need to be removed to access the SYNC button.
  4. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the Wii console.
  5. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  6. This sync procedure must be followed for each additional Wii Remote added to the system.
May 19, 2014 | Nintendo Wii Console
Cant get remotes to sync with wii unit. batteries are good
You dont say if you have pressed both red buttons.....to do this you must take battery cover off and locate small red button....then pull down sd card cover on front of wii and there you will find another red button.....press both at same time and they should sync with system
May 30, 2011 | Nintendo Video Game Consoles & Games
None of the controllers will work on my wii, we have changed the batteries but still nothing. We even bought a new controller. What would be wrong with it.
ok you will need to synchronization.Press the power button on the wii conosle to turn it on remove the battery cover on the backof the remote.Press and release the SYNC. button inside the cover.the player leds will blink.Open the fornt door on the wii console press and release the SYNC.button on the inside of the compartment. when the player LED blinking stop connection is complete the LED that is iluminated indicates the player number, THAT IS IT
Let me know if I help you out
Jan 02, 2011 | Nintendo Wii Console
Samsung SGH-a707 solid red screen and says download! PLEASE HELP!
Sir you probably have droped your phone in water...........thats the reason it displays DOWNLOAD on front display..........takeout the battery leave your phone in free air for a day or two to (Remember you dont have put the cover back)...........after two days put the batter back in phone your phone should work well now.........if problem still exists change the battery........
Mar 30, 2009 | Samsung SYNC SGH-A707 Cellular Phone
All i get when i turn my samsung sync a707 is a red screen help plz
Its one of the most common problem in Samsung SGH-A707.It is mainly due to one reason i,e. your cell got wet.....!!!
But you can try following steps to get rid of it:
1. Takeout the battery of your phone.
2. Leave your cell in air for a day or two without attaching battery and battery cover to it.
3. Put the battery back,it should work.If still problem exists, then I'll recommend you to buy a new battery for your cell........and before you put that new battery in your cell,leave your cell in air for another two days with the same procedure.
Thank You!And good luck!
Mar 05, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Samsung sync phone broken do i need a new battery
When you see the red screen it means the phone is in a "boot mode" - you would need to plug it in the computer vis a data cable and flash the phone with a current flash file.
Nov 18, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SYNC-A707 AT&T Cellular
Either the battery cover or the back housing is damaged. To fix it and fix it right, you need to replace the damaged part.
Look online, or check out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited.
Other than that, the only other option would be to tape it on.
Jul 25, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung Sync
Apr 17, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung Sync Red Battery Cover
if you've tried stores like radio shack, call the company or a parts provider...
i know..common sense and you could've figured that one out...ha.
Nov 20, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SYNC SGH-A707 Cellular Phone Logo
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Ekse
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
