Unit 10 years old. Developed small leak not where connects with supplied lines but behind brass connection leading into washlet unit. Further examination will require removing back of Washlet Main unit. Can I do this without further damage to main unit?
Check You Tube https://www.youtube.com/results?search_query=toto+washlet+repair
and see if one of their videos will help.
SOURCE: Toto C100 Toilet Washlet Seat
There are two types of bowls as far as toilets are concerned...elongated and round front. The seats are interchangable as long as there isn't anything different in the way the seat is mounted to the toilet. As far as I know and my experiance with both brands, I can't see any reason why it would not work.
SOURCE: ToTo S300 spray very weak
Poor some clr in the washer bottleand block the nozzles as you run the clr through. they will clear up, but don't leave the clr on your paint or in the washer bottle. Rinse everything out and off.
SOURCE: Installing Washlet toilet seat on Toto toilet
The water supply line on your Aquia toilet was installed before the tank was mounted to the bowl and the tank must be removed to change it.
SOURCE: Toto Washlet C100: main cleansing
If the front to back clean washlet is not working that means to get it to work you need to replace the seat. Call toto I heard that there was a recall on them.
Customer Service & Technical Support
Tel: 1-888-295-8134
[email protected]
[email protected]
Good Luck
SOURCE: Itchy rash on my bottom.
Hello
You should use the TOTO without the deodorizing sprayer for a few days and see if there is a change but i doubt that it has anything to do with the agent. Maybe you just have a very sensitive skin that reacts to some ingridients in the deodorizer
Did you ever get this problem resolved?
I have sem issue
