SOURCE: How do I earase the M2 button that is always on my screen?
Clear the display so that zero shows, then press STO M2 to store zero in the M2 registry. Any time there is a non-zero number stored in M1, M2 or M3, you will see those memories in the display to remind you there's something stored. There is no "clear memory" function on the TI-30XA, you have to store zero in the memory to clear M1, M2 or M3 from the display.
David
SOURCE: rounding function on my TI-30xIIs calculator, it won't turn off.
This function is FIX or FSE near the dot [.] or above it, so press
[2nd] the the [FIX] where it located button [.] for example then the
dot [.] him self: [2nd] [FIX] [.]
Rate me, thanks.
SOURCE: Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
SOURCE: my ti 30 calculator always rounds to the nearest
To stop the calcultor rounding your answers to the nearest INTEGER, press [2nd][FIX] followed by a number other than 0. For exemple
[2nd][FIX] 3 will display the numbers with 3 decimal digits.
Hope it helps.
Thank you for using FixYa.
SOURCE: how do i enter pH on a TI 30 calculator
This post answers two questions
If you are not interested in the theory, jump to the examples at the end of the post.
As you well know the pH is the negative of the log in
base 10 of the H+/H3O+ ion concentration. If we use [H+] to represent
that concentration, then pH=-log[H+].
To obtain the [H+] you need to calculate the antilog. You write the definition in the form log[H+] =-pH and then calculate 10 to the power of each member. The equality remains valid as both members are treated similarly. Thus
10^( log[H+] ) = 10^(-pH)
Since
raising 10 to a power is the inverse function of taking the log in base
10, 10^(log(x))=log(10^(x)) = x (they are inverse of one another), you
are left with
[H+]=10^(-pH)
Your calculator has a function [10 to x] accessed by pressing the [2nd] function key. To use it you must enter the negative value of the pH, press the [2nd] function key then the [10 to x], then the = key to get the result (concentration)
Examples
1. Let the pH=5.5, what is the H+ concentration?
With [(-)] being the change sign key, then
[H+]:[ (-) ] 5.5 [2nd][10 to x] [=]
The result is 0.000003162 or 3.16 x 10^(-6)
Calculating the pH
Shortcut:
For all H+/H3O+ concentrations of the form 1.*10^(a) where a is an integer number between 0 and -14, the pH is the negative value of the exponent.
Concentration =10^(-3), pH=3
Concentration=10^(-11), pH=11
For other concentrations such as 3.567*10^(-8), one cannot use the shortcut above, but have to calculate the log of the concentration
[H+/H3O+] = 3.567*10^(-8)
pH= - log(3.567*10^(-8))
This is keyed in as follows (to minimize the number of parentheses)
8 (-) [2nd][10 to x] [*] 3.567 [LOG] [=] (-)
Here you have two (-) change sign, the first is entered after the exponent of 10, the other at the end of the calculation to take the negative of the displayed result. You may notice that it is entered in the reverse order of the defining relation - log(3.567*10^(-8)).
To verify your calculation, the result is 7.447696891 or just 7.45
If you have a problem with the first (-) try entering it before you type in 8.
Hope it helps and thank you for using FixYa
And please, show your appreciation by rating the solution.
